[Swift-devel] Re: swift plot
    Ben Clifford
    benc at hawaga.org.uk
    Mon Apr 13 09:11:35 CDT 2009
The graph on the front page 'Number of karajan level job submissions that
are 'Active'' looks like for the most part only 1 or 2 CPUs were in use at
any one time.
That seems not so good - either 1 or 2 CPUs really were in use at any one
time, which is not good for the app perspective, or maybe the execution
provider that you are using is not reporting job statuses correctly.
For comparison, run with:
wrapperlog.always.transfer=true
in swift.properties, and make sure that if you move the .log file you move
the correspondingly named .d directory too, and then plot logs and make
sure that graphs on the info tab appear (they are broken images at the
moment).
That will give a worker-nodes view of how many CPU cores are being used as
once, for comparison.
