[Swift-devel] Re: replication vs site score
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Apr  9 12:34:26 CDT 2009
Mihael Hategan wrote:
> On Thu, 2009-04-09 at 10:12 -0700, Ioan Raicu wrote:
>> No workers sit idle, waiting for other workers to start. The resource
>> allocation takes some amount of time to boot up the OS on each node,
>> mount GPFS, start Falkon service, start Falkon workers, etc... see
>> http://dev.globus.org/wiki/Image:Falkon-BGP-startup-time.jpg. Its true
>> that there is some difference between the 1st worker starting, and the
>> last worker starting, probably on the order of seconds to maybe minutes
>> at the largest scale of 160K processors. If this is a concern, the idle
>> time as the system starts up, you can start Swift before 100% of the
>> system is operational. The system is partitioned in 64 node chunks, so,
>> in theory, Swift could start as soon as 64 nodes are online. Although,
>> this could also have its own problems.
> This assumes a single site and exact knowledge of how to fit the
> workload.
Nope, its a single site if you want to start at the earliest possible
time, but once all nodes are started, it becomes a multi-site
allocation, where each site is a 64 node chunk of the allocation.
> I also assume this works when you have a reservation, otherwise you may
> have better chances with smaller chunks.
Up to 8K cores, we usually run without reservations. Beyond that, we do
get reservations.
Ioan Raicu, Ph.D.
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090409/5e622013/attachment.html>
