[Swift-devel] Re: Probing running jobs
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Apr  5 09:59:29 CDT 2009
On Sat, 2009-04-04 at 22:21 +0000, Ben Clifford wrote:
> On Sat, 4 Apr 2009, Mihael Hategan wrote:
> > It won't start you in the job directory, but the swift workflow
> > directory. That's because at some point we stopped using the GRAM
> > directory attribute for setting the initial job dir because some silly
> > site on OSG doesn't honor it. I think we should revisit the issue (I
> > suspect there is a solution that works in both cases).
> I think that has not been the case since at least before the CI SVN
> started to be used.
> The first mention of specifying a directory attribute for task:execute in
> execute2 was r127, which specified wfdir. Before that, no directory was
> specified at all.
> The job directory has seemingly always been passed as a parameter of one
> kind or another to the wrapper script.
You are right. I was confused.
