[Swift-devel] Re: swift+glite
Stuart Martin
smartin at mcs.anl.gov
Wed Sep 10 10:37:40 CDT 2008
Are you going through gram for this? How will you get the delegated
user proxy on the worker node without a shared FS? You'll need to get
that in order to do gridftp client commands on the worker node.
On Sep 10, 2008, at Sep 10, 10:20 AM, Ben Clifford wrote:
> On Wed, 10 Sep 2008, Michael Wilde wrote:
>> Please post info on what is needed in IO changes. I think this fits
>> in with
>> generalizing and improving the performance of the Swift IO strategy
>> for other
>> environments as well.
>> What is the data transfer strategy when there is no cluster file
>> system? Does
>> the compute node need to pull data down as a gridftp client?
> That's what I'm trying to do at the moment, using a site-local ftp
> server
> (that apparently doesn't share fs with the compute nodes).
> That seems relatively straightforward.
> There's a separate problem with no-shared-fs in that the wrapper
> script is
> also placed there prior to execution on the worker nodes, so a
> different
> mechanism for bootstrapping that on a worker node is necessary.
> At the moment, I'm concentrating specifically on glite-specific
> mechanisms, not making a higher abstraction.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
