[Swift-devel] Re: swift+glite
Ben Clifford
benc at hawaga.org.uk
Wed Sep 10 10:20:10 CDT 2008
On Wed, 10 Sep 2008, Michael Wilde wrote:
> Please post info on what is needed in IO changes. I think this fits in with
> generalizing and improving the performance of the Swift IO strategy for other
> environments as well.
> What is the data transfer strategy when there is no cluster file system? Does
> the compute node need to pull data down as a gridftp client?
That's what I'm trying to do at the moment, using a site-local ftp server
(that apparently doesn't share fs with the compute nodes).
That seems relatively straightforward.
There's a separate problem with no-shared-fs in that the wrapper script is
also placed there prior to execution on the worker nodes, so a different
mechanism for bootstrapping that on a worker node is necessary.
At the moment, I'm concentrating specifically on glite-specific
mechanisms, not making a higher abstraction.
