[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 17:27:59 CDT 2008
Mihael Hategan wrote:
> On Thu, 2008-10-02 at 17:24 -0500, Mihael Hategan wrote:
>>>> On Thu, 2008-10-02 at 17:06 -0500, Zhao Zhang wrote:
>>>>> I applied it in /home/falkon/cog
>>>>> and run swift -sites.file ./sites.xml -tc.file ./tc.data sleep.swift in
>>>>> /home/falkon/cog/module/vdsk
>>>> Please type the following and post the output:
>>>> cd /home/falkon/cog/module/vdsk
>>>> which swift
>>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk> which swift
>>> /home/falkon/cog/modules/vdsk/dist/vdsk-svn/bin/swift
>>>> grep -n "check" dist/vdsk-svn/libexec/vdl-int.k
>>> zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk> grep -n "check"
>>> 63: element(checkJobStatus, [rhost, wfdir, jobid, tr, jobdir]
>> Do you have anything in $CLASSPATH?
> Also, do you have anything in $SWIFT_HOME?
> i.e. what is the output of the following:
> echo $CLASSPATH
zzhang at login6.surveyor:~/swift/etc> echo $CLASSPATH
.:/home/falkon/falkon/container:/home/falkon/falkon/container/build/classes:/home/falkon/falkon/container/lib/addressing-1.0.jar:/home/falkon/falkon/container/lib/axis.jar:/home/falkon/falkon/container/lib/axis-url.jar:/home/falkon/falkon/container/lib/bootstrap.jar:/home/falkon/falkon/container/lib/cog-axis.jar:/home/falkon/falkon/container/lib/cog-jglobus.jar:/home/falkon/falkon/container/lib/cog-tomcat.jar:/home/falkon/falkon/container/lib/cog-url.jar:/home/falkon/falkon/container/lib/commonj.jar:/home/falkon/falkon/container/lib/commons-beanutils.jar:/home/falkon/falkon/container/lib/commons-cli-2.0.jar:/home/falkon/falkon/container/lib/commons-collections-3.0.jar:/home/falkon/falkon/container/lib/commons-digester.jar:/home/falkon/falkon/container/lib/commons-discovery.jar:/home/falkon/falkon/container/lib/commons-logging.jar:/home/falkon/falkon/container/lib/concurrent.jar:/home/falkon/falkon/container/lib/cryptix32.jar:/home/falkon/falkon/container/lib/cryptix-asn1.jar:/home/falkon/falkon/container/lib/cryptix.jar:/home/falkon/falkon/container/lib/globus_delegation_service.jar:/home/falkon/falkon/container/lib/globus_delegation_stubs.jar:/home/falkon/falkon/container/lib/globus_usage_core.jar:/home/falkon/falkon/container/lib/globus_usage_packets_common.jar:/home/falkon/falkon/container/lib/globus_wsrf_mds_aggregator_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rendezvous_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rft_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_tools_test.jar:/home/falkon/falkon/container/lib/gram-client.jar:/home/falkon/falkon/container/lib/gram-stubs.jar:/home/falkon/falkon/container/lib/gram-utils.jar:/home/falkon/falkon/container/lib/jaxrpc.jar:/home/falkon/falkon/container/lib/jce-jdk13-125.jar:/home/falkon/falkon/container/lib/jgss.jar:/home/falkon/falkon/container/lib/junit.jar:/home/falkon/falkon/container/lib/log4j-1.2.8.jar:/home/falkon/falkon/container/lib/naming-common.jar:/home/falkon/falkon/container/lib/naming-factory.jar:/home/falkon/falkon/container/lib/naming-java.jar:/home/falkon/falkon/container/lib/naming-resources.jar:/home/falkon/falkon/container/lib/nom_tam.jar:/home/falkon/falkon/container/lib/opensaml.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_common.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS_stubs.jar:/home/falkon/falkon/container/lib/puretls.jar:/home/falkon/falkon/container/lib/resolver.jar:/home/falkon/falkon/container/lib/saaj.jar:/home/falkon/falkon/container/lib/servlet.jar:/home/falkon/falkon/container/lib/swing-layout-1.0.jar:/home/falkon/falkon/container/lib/wsdl4j.jar:/home/falkon/falkon/container/lib/wsrf_common.jar:/home/falkon/falkon/container/lib/wsrf_core.jar:/home/falkon/falkon/container/lib/wsrf_core_registry.jar:/home/falkon/falkon/container/lib/wsrf_core_registry_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_index_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_usefulrp_schema_stubs.jar:/home/falkon/falkon/container/lib/wsrf_provider_jce.jar:/home/falkon/falkon/container/lib/wsrf_test_interop.jar:/home/falkon/falkon/container/lib/wsrf_test_interop_stubs.jar:/home/falkon/falkon/container/lib/wsrf_test.jar:/home/falkon/falkon/container/lib/wsrf_test_unit.jar:/home/falkon/falkon/container/lib/wsrf_test_unit_stubs.jar:/home/falkon/falkon/container/lib/wsrf_tools.jar:/home/falkon/falkon/container/lib/wss4j.jar:/home/falkon/falkon/container/lib/xalan.jar:/home/falkon/falkon/container/lib/xercesImpl.jar:/home/falkon/falkon/container/lib/xml-apis.jar:/home/falkon/falkon/container/lib/xmlsec.jar
> echo $SWIFT_HOME
zzhang at login6.surveyor:~/swift/etc> echo $SWIFT_HOME
