[Swift-devel] could swift use return	code	from	falkon	as	a	success notification?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Oct  2 17:25:48 CDT 2008
On Thu, 2008-10-02 at 17:24 -0500, Mihael Hategan wrote:
> > > On Thu, 2008-10-02 at 17:06 -0500, Zhao Zhang wrote:
> > >> I applied it in /home/falkon/cog
> > >> and run swift -sites.file ./sites.xml -tc.file ./tc.data sleep.swift in
> > >> /home/falkon/cog/module/vdsk
> > > Please type the following and post the output:
> > > cd /home/falkon/cog/module/vdsk
> > > which swift
> > zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk> which swift
> > /home/falkon/cog/modules/vdsk/dist/vdsk-svn/bin/swift
> > > grep -n "check" dist/vdsk-svn/libexec/vdl-int.k
> > zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk> grep -n "check"
> > 63:             element(checkJobStatus, [rhost, wfdir, jobid, tr, jobdir]
> Do you have anything in $CLASSPATH?
Also, do you have anything in $SWIFT_HOME?
i.e. what is the output of the following:
echo $CLASSPATH
echo $SWIFT_HOME
