[Swift-devel] large run plot
Ian Foster foster at anl.gov
Tue Nov 4 05:43:38 CST 2008
nice!
On Nov 3, 2008, at 5:48 PM, Mihael Hategan wrote:
> On Mon, 2008-11-03 at 23:11 +0000, Ben Clifford wrote:
>> On Mon, 3 Nov 2008, Mihael Hategan wrote:
>>> So I tried to use the log tools to plot this rather large log.
>>> Various
>>> errors happened which ultimately led to the whole thing failing. The
>>> beast is /home/hategan/logs/modgenproc-20081103-1350-1ht9bn7d.log
>>> @ci.
>> I just ran with a fresh checkout of log-processing r 2318 (last
>> changed
>> r2296) on communicado, and it completes giving this:
>> http://www.ci.uchicago.edu/~benc/tmp/report-modgenproc-20081103-1350-1ht9bn7d/
> Well, that's what I wanted. It's a 65000 job CNARI run on Ranger.
> May be
> interesting to look at. Mostly because it runs in about 40 minutes,
> which I think is a fairly good number for both Swift and CNARI.
>> On the way, there are some errors about head -n needing parameters,
>> which
>> I have not seen before but will investigate; these are non-fatal
>> except
>> that they prevent the generation of certain graphs.
>> Does this correspond with what you saw?
> Yes, though there were some other errors. I'll have to update to
> latest
> code and try again.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
