[Swift-devel] large run plot
Mihael Hategan hategan at mcs.anl.gov
Mon Nov 3 17:48:36 CST 2008
On Mon, 2008-11-03 at 23:11 +0000, Ben Clifford wrote:
> On Mon, 3 Nov 2008, Mihael Hategan wrote:
> > So I tried to use the log tools to plot this rather large log. Various
> > errors happened which ultimately led to the whole thing failing. The
> > beast is /home/hategan/logs/modgenproc-20081103-1350-1ht9bn7d.log @ci.
> I just ran with a fresh checkout of log-processing r 2318 (last changed
> r2296) on communicado, and it completes giving this:
> http://www.ci.uchicago.edu/~benc/tmp/report-modgenproc-20081103-1350-1ht9bn7d/
Well, that's what I wanted. It's a 65000 job CNARI run on Ranger. May be
interesting to look at. Mostly because it runs in about 40 minutes,
which I think is a fairly good number for both Swift and CNARI.
> On the way, there are some errors about head -n needing parameters, which
> I have not seen before but will investigate; these are non-fatal except
> that they prevent the generation of certain graphs.
> Does this correspond with what you saw?
Yes, though there were some other errors. I'll have to update to latest
code and try again.
