[Swift-devel] large run plot
Ben Clifford benc at hawaga.org.uk
Mon Nov 3 17:11:40 CST 2008
On Mon, 3 Nov 2008, Mihael Hategan wrote:
> So I tried to use the log tools to plot this rather large log. Various
> errors happened which ultimately led to the whole thing failing. The
> beast is /home/hategan/logs/modgenproc-20081103-1350-1ht9bn7d.log @ci.
I just ran with a fresh checkout of log-processing r 2318 (last changed
r2296) on communicado, and it completes giving this:
http://www.ci.uchicago.edu/~benc/tmp/report-modgenproc-20081103-1350-1ht9bn7d/
On the way, there are some errors about head -n needing parameters, which
I have not seen before but will investigate; these are non-fatal except
that they prevent the generation of certain graphs.
Does this correspond with what you saw? If not, please send more detail.
