[Swift-devel] external datasets
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue May 27 18:10:54 CDT 2008
On Tue, 2008-05-27 at 23:08 +0000, Ben Clifford wrote:
> On Tue, 27 May 2008, Mihael Hategan wrote:
> > It should theoretically be able to handle restarts properly, no?
> With a variable-based restart mechanism, I think it will remember that the
> variable has been closed. With filename-based restarts, I think no.
Right.
> Perhaps restarting might bring up the same kind of problems as replication
> and retries - if some data processing got half-way through and then
> abandoned/broken/whatever, the various things Swift does to make
> application execution appear atomic wrt application output files won't
> happen here.
Also right. All we can do there is allow user-defined "compensation
handlers".
