[Swift-devel] [Bug 140] assorted GRAM4 own-hostname problems
bugzilla-daemon at mcs.anl.gov
Mon May 12 18:22:31 CDT 2008
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=140
hategan at mcs.anl.gov changed:
What |Removed |Added
Status|NEW |ASSIGNED
------- Comment #2 from hategan at mcs.anl.gov 2008-05-12 18:22 -------
I fixed a bunch of things.
One is that the swift ip setting has been deprecated in favor of "hostname",
which can also be used to specify a numeric ip.
Second one is the gt2 provider and gass servers, even though that's not used by
swift.
And the third would be different settings in the ws-gram client, and that is to
disable DNS resolutions. It seems like a general setting, which may have
unintended side effects, so testing should be done. For me it seems to work so
far.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You reported the bug, or are watching the reporter.
