[Swift-devel] Re: swift-falkon problem
Ioan Raicu
iraicu at cs.uchicago.edu
Thu Mar 20 19:03:24 CDT 2008
Here is more on sync:
> According to the standard specification (e.g., POSIX.1-2001), sync()
> schedules the writes, but may return before the
> actual writing is done. However, since version 1.3.20 Linux
> does actually wait. (This still does not guarantee data
> integrity: modern disks have large caches.)
So, it looks like it might be blocking, but it might depend on the Linux
kernel. Anyways, I think its worth a try, and it seems like a better
solution than sleeps.
Ioan
Ioan Raicu wrote:
> I added a configurable delay in delivering notifications to Swift in
> the provider code, which Mike still has to test. The deef provider
> already had a queue for the incoming notifications, so it was not hard
> to delay these notifications from this queue to Swift.
> Another approach, which I discussed with Mike, was to do a sync at the
> end of the wrapper script. From my simple test on a linux box, it
> seems that sync is a blocking call, which is exactly what we want!
> iraicu at gto:~> time sync
> real 0m0.711s
> user 0m0.000s
> sys 0m0.004s
> real 0m0.035s
> user 0m0.000s
> sys 0m0.000s
> Mike, could you try adding a sync at the end of the wrapper.sh (and
> make sure to not have any additional sleeps anywhere else), and see if
> that helps?
> Ioan
> Ben Clifford wrote:
>> There is flag for NFS mounts, 'noac', which disables attribute
>> caching on clients, which I think may make the fielsystem behave in
>> the desired fashion; however it sounds like it also massively reduces
>> filesystem performance and fileserver load.
>> Mike, you might be able to persuade MCS systems to make such a
>> filesystem available.
>> I suspect some multi-second delay after touching the status file and
>> before exiting in the wrapper script is probably the best workaround
>> for now, though.
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
