[Swift-devel] Re: swift-falkon problem
    Ben Clifford
    benc at hawaga.org.uk
    Thu Mar 20 18:23:06 CDT 2008
There is flag for NFS mounts, 'noac', which disables attribute caching on
clients, which I think may make the fielsystem behave in the desired
fashion; however it sounds like it also massively reduces filesystem
performance and fileserver load.
Mike, you might be able to persuade MCS systems to make such a filesystem
available.
I suspect some multi-second delay after touching the status file and
before exiting in the wrapper script is probably the best workaround for
now, though.
