[Swift-devel] Re: swift-falkon problem
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Mar 17 17:27:52 CDT 2008
On Mon, 2008-03-17 at 19:16 +0000, Ben Clifford wrote:
> On Mon, 17 Mar 2008, Ioan Raicu wrote:
> > > Failed to transfer wrapper log from amps1-20080316-1643-g4n8t252/info/0/sico
> > I don't understant this error, how is this error text being generated?  Falkon
> > only returns back a numeric exit code.  Could this error be a post processing
> > error when Swift couldn't manipulate the local file system, or it couldn't
> > find some expecting files?  What exit code does Falkon return for this task,
> > 0, or something else?
> That bit is a follow-on error, so pretty much ignore it - I haven't
> figured out what the right thing to do is for presenting it to the user.
> Basically:
>   1. swift tries to run an execuable (using provider-deef, in this case)
>   2. run of executable fails (i.e. provider-deef is passing back an erro)
>   3. swift tries to stage back the wrapper log to help diagnosis
Should it perhaps be maybe(transfer(wrapper_log)) instead of
transfer(wrapper_log)?
>   4. the wrapper log doesn't exist (presumably the wrapper never executed
> that far in the failed executable step 1)
>   5. swift reports the above error/warning that step 3 failed.
> So that line is an error that is a follow on from step 1 failing.
> > We need to figure out if the failure is in executing the tasks in Falkon, or
> > if that is OK, and the error is in Swift not finding some files afterwards.
> Provider-deef is reporting that execution failed. So its not the second
> one of those. But there isn't enough log information in mike's report to
> indicate where below the swift/provider-deef interface the error is
> occurring.
> The present swift+falkon joint deployment code still seems screwy enough
> to not merge in the provider-deef log4j command, which is annying. I'll
> have a look at that.
