[Swift-devel] Re: swift-falkon problem
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon Mar 17 15:24:54 CDT 2008
The attachment is the BGexec source code to use with both non-swift and
swift. To use it, first compile it like "gcc -o BGexec BGexec.c", run
invoke it, run "./BGexec 127.0.0.1 55000 55001 -debug swift" the last
option is to indicate that we are running BGexec with swift, if not
simply change it to no.
zhao
Michael Wilde wrote:
> Sorry - another mis-diagnosis and incorrect conclusion on my part.
> Zhao just told me that we have out of date falkon worker code on the
> sicortex that is not chdir'ing to the cwd arg of the falkon request.
> That explains what Im seeing. Its being fixed now and checked in.
> To answer your questions though:
> Im running swift on a linux box bblogin.mcs.anl.gov
> It mounts the sicortex under /sicortex-homes
> I run swift from /sicortex-homes/wilde/amiga/run
> My sites file says:
> <pool handle="sico">
>       <gridftp  url="local://localhost"/>
>       <execution provider="deef"
> url="http://140.221.37.30:50001/wsrf/services/GenericPortal/core/WS/GPFactoryService"/>
>       <workdirectory>/home/wilde/swiftwork</workdirectory>
> </pool>
> and /home/wilde/swiftwork on bblogin is a symlink to
> /sicortex-homes/wilde/swiftwork
> so that when swift writes files to the sicortex dir (eg when it
> creates shared/*) its using the same pathname that the worker-side
> will use when the job runs.  Ie, even though the mount-points differ
> between the swift host and the worker host, symlinks make the workdir
> appear under same name on both sides.
> If NFS adheres to its close-to-open-coherence semantics, this then
> should I think work.
> My scp-provider question is probably still worth answering and trying
> if this doesnt work.
> - Mike
> On 3/17/08 2:57 PM, Ben Clifford wrote:
>> what does your filesystem layout look like?
>> Where are you running swift? And where are you putting your scicortex
>> site directory? On an NFS that is also accessible from your submit
>> machine? If so, what path?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080317/2017f87c/attachment.c>
