[Swift-devel] Re: swift-falkon problem
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 17 15:19:23 CDT 2008
Sorry - another mis-diagnosis and incorrect conclusion on my part.
Zhao just told me that we have out of date falkon worker code on the
sicortex that is not chdir'ing to the cwd arg of the falkon request.
That explains what Im seeing. Its being fixed now and checked in.
To answer your questions though:
Im running swift on a linux box bblogin.mcs.anl.gov
It mounts the sicortex under /sicortex-homes
I run swift from /sicortex-homes/wilde/amiga/run
My sites file says:
<pool handle="sico">
       <gridftp  url="local://localhost"/>
       <execution provider="deef"
url="http://140.221.37.30:50001/wsrf/services/GenericPortal/core/WS/GPFactoryService"/>
       <workdirectory>/home/wilde/swiftwork</workdirectory>
</pool>
and /home/wilde/swiftwork on bblogin is a symlink to
/sicortex-homes/wilde/swiftwork
so that when swift writes files to the sicortex dir (eg when it creates
shared/*) its using the same pathname that the worker-side will use when
the job runs.  Ie, even though the mount-points differ between the swift
host and the worker host, symlinks make the workdir appear under same
name on both sides.
If NFS adheres to its close-to-open-coherence semantics, this then
should I think work.
My scp-provider question is probably still worth answering and trying if
this doesnt work.
- Mike
On 3/17/08 2:57 PM, Ben Clifford wrote:
> what does your filesystem layout look like?
> Where are you running swift? And where are you putting your
> scicortex site directory? On an NFS that is also accessible from your
> submit machine? If so, what path?
