[Swift-devel] Re: swift-falkon problem
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 17 14:53:38 CDT 2008
OK, thanks, will do.
My earlier message that "it worked" was premature - my sites file was
doing local execution.
I pushed forward past a few other errors and am now stuck as follows.
As far as I can tell Im now getting the "NFS not syncing" problem.
Swift creates the working dir for the workflow as a local file reference
to an NFS-mounted directory. When swift tells falkon to run
shared/wrapper.sh, its not there yet.  When I look after the workflow
has failed, it is indeed there.
What I'd rather do here is tell swift to use scp rather than
direct-file-access as the data provider.  Do you know how to do that? Or
are there any other data transports to consider?
(One alternative is to get gridftp running on sico).
On 3/17/08 2:19 PM, Ben Clifford wrote:
> On Mon, 17 Mar 2008, Ioan Raicu wrote:
>> iraicu at viper:~/java/svn/cog/modules/provider-deef/etc> cat
>> log4j.properties.module
>> log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
>> log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
>> I have this log4j property, do you have this enabled?  This should
>> enable more debug output from the Falkon provider.
> If deploying swift with this command: ant -Dwith-provider-deef redist
> then it looks like those lines don't get merged in. Mike, add those lines
> yourself to your dist/swift-0.3-dev/etc/log4j.properties file.
