[Swift-devel] Re: swift-falkon problem
    Ben Clifford
    benc at hawaga.org.uk
    Mon Mar 17 14:19:39 CDT 2008
On Mon, 17 Mar 2008, Ioan Raicu wrote:
> iraicu at viper:~/java/svn/cog/modules/provider-deef/etc> cat
> log4j.properties.module
> log4j.logger.org.apache.axis.utils.JavaUtils=ERROR
> log4j.logger.org.globus.cog.abstraction.impl.execution.deef=DEBUG
> I have this log4j property, do you have this enabled?  This should
> enable more debug output from the Falkon provider.
If deploying swift with this command: ant -Dwith-provider-deef redist
then it looks like those lines don't get merged in. Mike, add those lines
yourself to your dist/swift-0.3-dev/etc/log4j.properties file.
