[Swift-devel] Re: Question of wrapper.sh
Zhao Zhang zhaozhang at uchicago.edu
Sun Mar 9 20:55:53 CDT 2008
Hi, Ben
Here is the script that we are using to build the provider
#/bin/sh
if [ -z "${FALKON_ROOT}" ]; then
    echo "ERROR: environment variable FALKON_ROOT not defined"  1>&2
    return 1
fi
if [ ! -d "${FALKON_ROOT}" ]; then
    echo "ERROR: invalid FALKON_ROOT set: $FALKON_ROOT" 1>&2
    return 1
fi
cd ${FALKON_ROOT}/cog/modules/provider-deef
ant distclean
ant -Ddist.dir=../vdsk/dist/vdsk-0.3-dev/ dist
So I need to delete the last line and add
ant -Dwith-provider-deef -Ddist.dir=../vdsk/dist/vdsk-0.3-dev/ redist
right?
zhao
Ben Clifford wrote:
> On Sun, 9 Mar 2008, Zhao Zhang wrote:
>> well, the tar ball I sent in the last email is from 256 cores, are they from
>> the same cpu? By the way, I tried to find the .log files, but there isn't any
>> in the folder where I started the swift script.
> How are you building provider-deef? The old way messes up logging. Since
> r1525 in December, a way to build that doesn't do this is to build swift
> and provider-deef at the same time, by using this command in the vdsk
> directory:
>   ant -Dwith-provider-deef redist
> You'll get a warning like this:
>  [input] Warning! The specified target directory
> (/Users/benc/work/cog/modules/swift/../..//modules/swift/dist/swift-0.3-dev)
> does not seem to contain a Swift build.
> which is not a problem - press return a few times to get the build to
> continue.
