[Swift-devel] Re: Question of wrapper.sh
    Ben Clifford
    benc at hawaga.org.uk
    Sun Mar  9 19:54:05 CDT 2008
On Sun, 9 Mar 2008, Ioan Raicu wrote:
> Those logs are only for 1 CPU, so most things will take less than 1 sec.  In
> the case where we use 100s of CPUs (a basic scenario for the BG/P), things
> will take 10s of seconds, so 1 sec resolution should be OK.  Zhao, did you
> re-run that test with 256 CPUs?  Ben should be looking at those logs, not the
> 1 CPU case.
OK. That will be more interesting then. Zhao, please send the regular .log
file at the same time too.
