[Swift-devel] Re: Question of wrapper.sh
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Sun Mar  9 19:51:20 CDT 2008
Ben,
Those logs are only for 1 CPU, so most things will take less than 1
sec.  In the case where we use 100s of CPUs (a basic scenario for the
BG/P), things will take 10s of seconds, so 1 sec resolution should be
OK.  Zhao, did you re-run that test with 256 CPUs?  Ben should be
looking at those logs, not the 1 CPU case.
Ioan
Ben Clifford wrote:
> Whichever version of date that you used, it doesn't support more than 1s
> accuracy in its output. That's irksome because its that subsecond accuracy
> that I wanted from these log files.
> date on os x doesn't have that precision, fairly recent (in the past
> couple of years at least) GNU coreutils date does. It would be nice if you
> could find if that is installed and use that instead...
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
