[Swift-devel] Re: Question of wrapper.sh
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Mar  7 07:40:08 CST 2008
Ben Clifford wrote:
> On Fri, 7 Mar 2008, Ioan Raicu wrote:
>>> I notice you're using quite an old version of swift
>> iraicu at login1.surveyor:/home/zzhang/cog/modules/vdsk> svn info
>> Revision: 1673
> Zhao's log reported this:
> zhaozhang at viper:~/vdsk-0.3/examples/vdsk> swift first.swift
> Swift v0.3 r1319 (modified locally)
Notice that this Swift is from viper, a machine in RI.  He might be
playing with this to get used to learning about Swift, but that is not
being used on the BG/P in any way, as everything we run on the BG/P
needs to run from the login nodes.  Zhao, can you confirm that the runs
you are making with Swift on the BG/P are indeed using a recent
version?  Can you also do an update of Swift on the BG/P to make sure we
have the latest?
> which is nowhere near the version that you report - something in the 1600s
> is a reasonable number, but that's not what the log output was. So please
> clarify which version you actually have poor behaviour for. If it is in
> the r1600 range, then I'm interested to fix up - but in the r1600s there
> should be absolutely no cross-node shared log files at all.
>> Every job still has a scratch space sandbox, which results in a mkdir,
>> symbolic linking, and finally a cleanup remove dir.  I think this is the
>> dir he is referring to.  BTW, if there would be an easy way to eliminate
>> this entire mkdir part of the wrapper script without breaking anything
>> in Swift, it would be nice.  The apps we are dealing with don't need the
>> sandboxing, as we know all input files, and all output files, and we'll
>> never have input as *.fits that might be ambiguous if we don't sandbox.
> If the jobs touch only those files, I think you can probably eliminate the
> mkdir, the ln to copy files in and the cp to copy files back out, and run
> the job in the shared directory directly. However, as each node will then
> be trying to do stuff to that shared directly, my initial thoughts would
> be that it wouldn't really change much (perhaps better, perhaps worse).
That is what I thought.  We'll try that and see what we get!  We'll keep
you posted.
Ioan
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080307/61e6c1de/attachment.html>
