[Swift-devel] workflow run with the newest Swift
Ben Clifford
benc at hawaga.org.uk
Sun Jun 29 07:20:24 CDT 2008
On Fri, 27 Jun 2008, lixi at uchicago.edu wrote:
> >Do you have the log file for this? I would like to see how
> it worked.
> It is on CI:
> /home/lixi/newswift/test/newversion/workflowtest-20080627-
> 1246-aba0l8d9.log
Some stats for that run:
Almost exactly 1h runtime.
Peak of 45 jobs actually running on workers at any one time; for most of
the hour between 30 and 45 jobs were running on workers. At peak, around
70 jobs were either queued or running.
The bulk of jobs took bang on 60s to execute on workers, with a relatively
small number taking much less or more (up to 75s for some) - that is
plotted in the 'info duration histograph' graph in the below URL.
13 different sites were tried. There is a breakdown of how much each was
used in 'sites/success table' in the below URL. The decent sites got 200
or so jobs each.
The log analyser doesn't deal with replication properly yet, but it looks
like around 10% of jobs (about 200) got replicated.
Looking at per-site stats, it looks like most sites did not get more than
6 jobs queued/running at once, rather than increasing. One site got 12
though. I'm interested to know what caused that. I think it is your choice
of jobThrottle parameter in your sites file generation. My rule of thumb
has been 20 jobs at once for GRAM2 and a few hundred at once for GRAM4;
are you specifying a lower job throttle in your submissions?
All the plots and stats are here:
http://www.ci.uchicago.edu/~benc/report-workflowtest-20080627-1246-aba0l8d9/
