[Swift-devel] Try coaster on BG/P ?
Michael Wilde
wilde at mcs.anl.gov
Thu Jun 19 18:50:21 CDT 2008
On 6/19/08 6:19 PM, Ben Clifford wrote:
> Probably would want to launch from somewhere else the coaster head node
> job and the coaster workers all in one go, by the sound of how things work
> on BG/P. The only mode that I've used coasters in so far doesn't do that -
> the coaster head node job launches workers as it percieves they are
> needed. Where you're being allocated a big chunk of the machine, it
> probably makes sense to run coasters on all of that chunk at once.
Yes, makes sense.
The BGP mechanism works as you say - the head-node job starts first, and
when it exits from its main process the BGP startup mechanism launches
the worker-node jobs. The server continues on the head node (the ION in
this case) asynchronously.
Whats the form of the coaster head-node job? Is that Java, or some form
of script? (I recall Java, but keep forgetting).
On the BGP, if the worker jobs connect back to the headnode process,
then it may be as easy as just starting them, with the right contact
info to reach the headnode.
Do you think Swift/Coaster will scale well if it had up to 640 servers,
one for each p-set of 256 compute cores? Thats one "natural" mode of
deployment.
Another mode is N servers total, where N can be any small number >=1,
but these N servers would run on a login node.
The issues seem to be connectivity, reachability (having all the
components find out how to reach each other), and then performance (how
will the algorithms behave in the different topologies).
