[Swift-devel] Try coaster on BG/P ?
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jun 19 15:20:55 CDT 2008
On Thu, 2008-06-19 at 15:07 -0500, Michael Wilde wrote:
> On 6/19/08 2:52 PM, Mihael Hategan wrote:
> > On Thu, 2008-06-19 at 14:47 -0500, Michael Wilde wrote:
> >> I *think* that both the login nodes and the compute nodes can reach the
> >> ION (and vice versa) on direct networks without NAT, hopefully allowing
> >> Coaster UDP communication to work.
> > I thought we agreed that UDP is not worth the trouble.
> If so, I either forgot or missed that in the email thread. But thats OK
> - I have no preference until the choice of protocol proves to be an
> issue for scalability or reliability. Have you switched the
> implementation to TCP?
Yes. A long time ago.
> >> Coaster is not  a high priority for this, but in the next few weeks I
> >> hope to start running the apps above under Swift.  If Coaster is ready
> >> to try on the BGP at that point, I'm eager to test it there. Before that
> >> I hope to test it first in an environment where it already works.
> >> Ben or Mihael, can you point me to (or write) a README on how to run
> >> Coaster?
> > Do you want to run a standalone service?
> Do you mean standalone as in "not started automatically by Swift via
> GRAM"?
Yes.
>   If so, I think yes: on the BGP, one mode would be to run one or
> more services from some Swift or related Coaster startup script, that
> would launch the service(s) - either one, on the login host on which
> you're running Swift, or on IO nodes, one per processor-set.
I don't think that's documented yet. I'll let you know when I have
something there.
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
