[Swift-devel] maling lists
Ioan Raicu
iraicu at cs.uchicago.edu
Thu Jun 5 13:48:19 CDT 2008
Incubator guidelines are probably easier to satisfy than once you are
ready to escalate, which should be most incubator's end goal.
Mihael Hategan wrote:
> On Thu, 2008-06-05 at 13:39 -0500, Ioan Raicu wrote:
>> This will be enough for being allowed back as an incubator, but it
>> will never suffice for escalating the project to being a full fledged
>> Globus component. They look at the mailing lists activity at review
>> time, and will judge the community size based on the number of people
>> that post questions and answers. So, your solution to ignore as much
>> as possible the globus mailing list is only a short term solution.
> It would seem silly to allow projects to have primary lists other than
> the ones at @globus.org, yet require that all meaningful activity
> happens on the ones @globus.org. "Primary" implies "where all meaningful
> stuff happens".
>> Ioan
>>> On Thu, 2008-06-05 at 17:30 +0000, Ben Clifford wrote:
>>>>> - subscribe all committers to the other @globus mailing lists. We'll
>>>>> encourage users to use the @ci mailing lists, and discussions initiated
>>>>> on @globus should be manually moved to @ci.
>>>> I think this is fairly ridiculous.
>>> That I can't deny.
>>>> We should not have multiple mailing lists for the same purpose. If we have
>>>> globus lists, the CI lists should be shut down and the community and
>>>> archives there abandoned or compelled to move.
>>> We wouldn't really use the @globus.org mailing lists. We fulfill our
>>> requirement (given that we have no choice), and we also make it so that
>>> we don't really fulfill the requirement. In other words we have the
>>> lists, we do what we're asked, but we tell everybody to use the other
>>> ones. And for the few cases when people ask questions on the @globus.org
>>> lists, we move the discussion.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu
>> Ph.D. Candidate
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web: http://www.cs.uchicago.edu/~iraicu
>> http://dev.globus.org/wiki/Incubator/Falkon
>> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
Ioan Raicu
Ph.D. Candidate
Chicago, IL 60637
