[Swift-devel] Re: Analysis of wrapper.sh
Michael Wilde wilde at mcs.anl.gov
Tue Jul 29 12:37:16 CDT 2008
Out of all the UML diagrams, I find sequence diagrams the most useful.
These are the ones where vertical bars represent parties in an
interaction, and horizontal lines indicate messages or interactions
between these parties. Often used to describe message protocols.
I would find (simplified) UML sequence diagrams to be useful in, eg,
documenting the logic of how the various parties of Coaster interact,
and I guess the same may apply to core Swift data management logic (in
the sense that there are multiple parties: Swift, the mappers, the
wrapper, and the app).
I once advocated doing this for documenting Falkon's logic.
So, yes, we can try this on both Coaster and data management
documentation and see how it works.
- Mike
On 7/29/08 12:29 PM, Ian Foster wrote:
> Mike, Zhao:
> This sounds like a great initiative.
> I wonder whether we can use UML to describe some of these things. Carl
> is pushing on this in a different context, and seems to be finding it
> useful.
> Ian.
> On Jul 29, 2008, at 12:27 PM, Michael Wilde wrote:
>> Thanks, Zhao.
>> Thats a good start. Where I want you to take this (with help form me
>> and others on the team) is to create a detailed description of how
>> data flows in Swift, for use by both end users and developers.
>> What you show here so far is mainly the wrapper code itself.
>> I'm looking for a diagram that shows the three main data locations,
>> and explains the important stages in data management during a
>> workflow, and what they mean, why they are done.
>> The three areas are: the data file's original location when the mapper
>> sees them; the shared dir on each site; the work dir on each compute
>> node.
>> Examples of questions I'd like this to cover are:
>> why do we have a shared dir? (Answer: to re-use transfered or
>> generated files within a workflow without re-transfering).
>> whats the lifetime of this directory? what in it is persistent vs
>> removed after jobs and/or scripts complete?
>> when does output come back? Where to?
>> how are relative vs absolute pathnames handled?
>> how are URL-prefixed pathnames handled? (gsiftp://, http:// etc?)
>> which Swift properties affect data management?
>> Same for options in profiles?
>> how should wrappers be written that reference files installed as part
>> of the application?
>> what are various ways in which wrappers and apps can utilize worker
>> node disk, today?
>> what patches that Ben implemented for testing in March-April on the
>> BGP and Sicortex are integrated and which remain patches to be
>> considered for testing and integration?
>> Some of these questions are more useful and make more sense than
>> others, but this is the general thing I want to get documented.
>> - Mike
>> On 7/29/08 12:02 PM, Zhao Zhang wrote:
>>> Hi, All
>>> I made this analysis of wrapper.sh. Correct me, if there is anything
>>> wrong. Thanks.
>>> zhao
>>> SWIFT phase: When swift is started, it creates a directory with the
>>> workload name and a random string, something like
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc
>>>                                                       |____info
>>>                                                       |____kickstart
>>>                                                       |____shared
>>> |____wrapper.sh
>>> |____seq.sh
>>>                                                       |____status
>>> WRAPPER.SH phase
>>> In my test case, the BGexec received a task in such a format
>>> "shared/wrapper.sh sleep-l5clzzvi -jobdir l -e /bin/sleep -out
>>> stdout.txt -err stderr.txt -i -d  -if  -of  -k  -a 600"
>>> with the working dir "/home/zzhang/swift/sleep-20080724-1527-qakbkkcc"
>>> WORKING_DIRECTORY
>>> OPERATION
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            OPEN
>>> wrapper.log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK if
>>> jobid ($1, sleep-l5clzzvi ) is empty    ----> empty exit with 254
>>> V
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Get
>>> -jobdir as $JOBDIR
>>> -jobdir ( l )is empty      ----> empty exit with 254
>>> V
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            mkdir -p
>>> $WFDIR/info/$JOBDIR   (mkdir
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc/info/l )
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -f
>>> "$WFDIR/info/$JOBDIR/${ID}-info" ( make a clean $ID-info file
>>> ID=sleep-l5clzzvi )
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            openinfo
>>> openinfo /home/zzhang/swift/sleep-20080724-1527-qakbkkcc/info/l/sleep-l5clzzvi-info)
>>> creating log file
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT
>>> "LOG_START" into log
>>> "Wrapper" into log
>>> -p $WFDIR/status/$JOBDIR (create status parent dir for the job "mkdir
>>> -p /home/zzhang/swift/sleep-20080724-1527-qakbkkcc/status/l ")
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PARSE the
>>> arguments
>>> ( EXEC=/bin/sleep, STDOUT=stdout.txt, STDERR=stderr.txt, STDIN=NULL,
>>> DIRS=null, INF=NULL, OUTF=NULL, KICKSTART=NULL)
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Check if
>>> there are arguments after -a  ----> empty exit with 254
>>> V
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            change $@
>>> from "-a 600" to "600"
>>> "$SIWFT_JOBDIR_PATH" is NULL ----> NO, local copy
>>> V
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            YES,
>>> shared file system. DIR=jobs/$JOBDIR/$ID ( DIR=jobs/l/sleep-l5clzzvi )
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            set PATH
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT all
>>> arguments into log
>>> "CREATE_JOBDIR" into log
>>> $DIR (In the working dir, "mkdir -p jobs/l/sleep-l5clzzvi ")
>>> "mkdir" is successful  ----> NO, exit with 254
>>> V
>>> YES, put "Created job directory : $DIR" into log
>>> "CREATE_INPUTDIR" into log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Created
>>> all subdirs in $DIR as in $DIRS ( create the same tree in
>>> jobs/l/sleep-l5clzzvi as in input file dir)
>>> "LINK_INPUTS" in to log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK file
>>> system type  ----> local disck, cp all files in $PWD/shared to $DIR
>>> V
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            shared
>>> file system, create links in  $DIR for all files in $PWD/shared
>>> "EXECUTE" into log
>>> "kickstart is enabled" ----> yes, use kickstart to run the job
>>> V
>>> NO, run the job with wrapper.sh
>>> "EXECUTE_DONE" into log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "Job
>>> ran successfully" into log
>>> the out put dir tree is the same as the one in $OUTF ----> NO, exit
>>> with 254
>>> V
>>> YES, COPY all output files in $DIR back to $PWD/shared
>>> "RM_JOBDIR" into log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -rf
>>> $DIR ("rm -rf jobs/l/sleep-l5clzzvi ")
>>> "TOUCH_SUCCESS" into log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            touch
>>> status/${JOBDIR}/${ID}-success ( touch
>>> status/l/)sleep-l5clzzvi-success )
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "END"
>>> into log
>>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            closeinfo
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
