[Swift-devel] Re: Analysis of wrapper.sh
    Ian Foster
    foster at mcs.anl.gov
    Tue Jul 29 12:29:01 CDT 2008
Mike, Zhao:
This sounds like a great initiative.
I wonder whether we can use UML to describe some of these things. Carl
is pushing on this in a different context, and seems to be finding it
useful.
Ian.
On Jul 29, 2008, at 12:27 PM, Michael Wilde wrote:
> Thanks, Zhao.
> Thats a good start. Where I want you to take this (with help form me
> and others on the team) is to create a detailed description of how
> data flows in Swift, for use by both end users and developers.
> What you show here so far is mainly the wrapper code itself.
> I'm looking for a diagram that shows the three main data locations,
> and explains the important stages in data management during a
> workflow, and what they mean, why they are done.
> The three areas are: the data file's original location when the
> mapper sees them; the shared dir on each site; the work dir on each
> compute node.
> Examples of questions I'd like this to cover are:
> why do we have a shared dir? (Answer: to re-use transfered or
> generated files within a workflow without re-transfering).
> whats the lifetime of this directory? what in it is persistent vs
> removed after jobs and/or scripts complete?
> when does output come back? Where to?
> how are relative vs absolute pathnames handled?
> how are URL-prefixed pathnames handled? (gsiftp://, http:// etc?)
> which Swift properties affect data management?
> Same for options in profiles?
> how should wrappers be written that reference files installed as
> part of the application?
> what are various ways in which wrappers and apps can utilize worker
> node disk, today?
> what patches that Ben implemented for testing in March-April on the
> BGP and Sicortex are integrated and which remain patches to be
> considered for testing and integration?
> Some of these questions are more useful and make more sense than
> others, but this is the general thing I want to get documented.
> - Mike
> On 7/29/08 12:02 PM, Zhao Zhang wrote:
>> Hi, All
>> I made this analysis of wrapper.sh. Correct me, if there is
>> anything wrong. Thanks.
>> zhao
>> SWIFT phase: When swift is started, it creates a directory with the
>> workload name and a random string, something like
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc
>>                                                       |____info
>>                                                       |____kickstart
>>                                                       |____shared
>> ____wrapper.sh
>> ____seq.sh
>>                                                       |____status
>> WRAPPER.SH phase
>> In my test case, the BGexec received a task in such a format
>> "shared/wrapper.sh sleep-l5clzzvi -jobdir l -e /bin/sleep -out
>> stdout.txt -err stderr.txt -i -d  -if  -of  -k  -a 600"
>> with the working dir "/home/zzhang/swift/sleep-20080724-1527-
>> qakbkkcc"
>> WORKING_DIRECTORY
>> OPERATION
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            OPEN
>> wrapper.log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            CHECK if
>> jobid ($1, sleep-l5clzzvi ) is empty    ----> empty exit with 254
>>        V
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Get -
>> jobdir as $JOBDIR
>> -jobdir ( l )is empty      ----> empty exit with 254
>>        V
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            mkdir -p
>> $WFDIR/info/$JOBDIR   (mkdir /home/zzhang/swift/sleep-20080724-1527-
>> qakbkkcc/info/l )
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -f
>> "$WFDIR/info/$JOBDIR/${ID}-info" ( make a clean $ID-info file
>> ID=sleep-l5clzzvi )
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            openinfo
>>        ( openinfo
>>  /home/zzhang/swift/sleep-20080724-1527-qakbkkcc/info/l/sleep-
>> l5clzzvi-info)
>>        creating
>>  log file
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT
>> "LOG_START" into log
>> "Wrapper" into log
>> -p $WFDIR/status/$JOBDIR (create status parent dir for the job
>> "mkdir -p /home/zzhang/swift/sleep-20080724-1527-qakbkkcc/status/l ")
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PARSE
>> the arguments
>>        ( EXEC
>> =/bin/sleep, STDOUT=stdout.txt, STDERR=stderr.txt, STDIN=NULL,
>>        DIRS
>> =null, INF=NULL, OUTF=NULL, KICKSTART=NULL)
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Check if
>> there are arguments after -a  ----> empty exit with 254
>>        V
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            change
>> $@ from "-a 600" to "600"
>> "$SIWFT_JOBDIR_PATH" is NULL ----> NO, local copy
>>        V
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            YES,
>> shared file system. DIR=jobs/$JOBDIR/$ID ( DIR=jobs/l/sleep-
>> l5clzzvi )
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            set PATH
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT all
>> arguments into log
>> "CREATE_JOBDIR" into log
>> $DIR (In the working dir, "mkdir -p jobs/l/sleep-l5clzzvi ")
>> "mkdir" is successful  ----> NO, exit with 254
>>        V
>>        YES
>> , put "Created job directory : $DIR" into log
>> "CREATE_INPUTDIR" into log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            Created
>> all subdirs in $DIR as in $DIRS ( create the same tree in jobs/l/
>> sleep-l5clzzvi as in input file dir)
>> "LINK_INPUTS" in to log
>> file system type  ----> local disck, cp all files in $PWD/shared to
>> $DIR
>>        V
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            shared
>> file system, create links in  $DIR for all files in $PWD/shared
>> "EXECUTE" into log
>> "kickstart is enabled" ----> yes, use kickstart to run the job
>>        V
>>        NO
>> , run the job with wrapper.sh
>> "EXECUTE_DONE" into log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            PUT "Job
>> ran successfully" into log
>> the out put dir tree is the same as the one in $OUTF ----> NO, exit
>> with 254
>>        V
>>        YES
>> , COPY all output files in $DIR back to $PWD/shared
>> "RM_JOBDIR" into log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            rm -rf
>> $DIR ("rm -rf jobs/l/sleep-l5clzzvi ")
>> "TOUCH_SUCCESS" into log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            touch
>> status/${JOBDIR}/${ID}-success ( touch status/l/)sleep-l5clzzvi-
>> success )
>> "END" into log
>> /home/zzhang/swift/sleep-20080724-1527-qakbkkcc            closeinfo
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
