[Swift-devel] Problems running coaster
Mihael Hategan
hategan at mcs.anl.gov
Sun Jul 27 23:07:51 CDT 2008
There's something I'm missing here. What sites.xml file are you using?
On Sun, 2008-07-27 at 22:50 -0500, Michael Wilde wrote:
> On 7/27/08 2:51 PM, Ben Clifford wrote:
> > I got the logs eventually.
> > On the Abe log, I see this error:
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > Task ended before registration was received.
> > STDOUT: This node is in dedicated user mode.
> > The string 'This node is in dedicated user mode.' is coming from
> > something outside of Swift, perhaps the local scheduler getting upset by
> > coasters. Could you submit successfully without coasters at the same time
> > (within a few minutes) of not being able to submit with coasters?
> Yes. Just *before* I tried abe with coasters, I did a simple
> globus-job-run to its pbs jobmanager. That worked fine.
> Ive sent ticket to TG Help asking if they recognize the "dedicated" message.
> Is the coaster server started with any special GRAM attributes, that I
> could provide to globus-job-run or globusrun to try to re-create the
> problem?
> > For the localhost run, have a look in your home directory root for coaster
> > and coaster worker log files that were generated at the same time as you
> > did that run and send those / look in them.
> I found the localhost problem in these logs - I didnt realize I needed a
> grid proxy for localhost coaster runs. I made one, and that works now.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
