[Swift-devel] Problems running coaster
Ben Clifford benc at hawaga.org.uk
Sun Jul 27 14:51:32 CDT 2008
I got the logs eventually.
On the Abe log, I see this error:
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Task ended before registration was received.
STDOUT: This node is in dedicated user mode.
The string 'This node is in dedicated user mode.' is coming from
something outside of Swift, perhaps the local scheduler getting upset by
coasters. Could you submit successfully without coasters at the same time
(within a few minutes) of not being able to submit with coasters?
For the localhost run, have a look in your home directory root for coaster
and coaster worker log files that were generated at the same time as you
did that run and send those / look in them.
