[Swift-devel] Drop kickstart, adopt wrapper logs?
Mihael Hategan hategan at mcs.anl.gov
Fri Jul 25 11:25:16 CDT 2008
On Fri, 2008-07-25 at 11:06 -0500, Michael Wilde wrote:
> If you do take this off for weekend work (which sounds like a good idea,
> modulo the weekend part ;) lets first set a design decision making
> process on the issues that have been raised in discussions to date:
Well, it was about removing kickstart which is somewhat different from
improving the wrapper to be like kickstart.
But we should discuss this.
> - arg passing
It's there.
> - what it captures
>    - time, mem
I suppose regular snapshots of those.
>    - env (in the broad sense)
I think it's there.
>    - file state
> - output format(s)
> - snapshotting for monitoring an app run
> - controls for start, stop, pause
> - how it integrates in CoG, GRAM, Condor, other LRMs, Coaster, Falkon,
> and Swift
It's the wrapper.
> - how it relates to "accounting" projects in OSG and TG
> - ideas on streaming output
As in stdout?
> - idead on batching output
> - interaction with a collective I/O toolkit/model
> - other stuff???
> Its worth looking at what Jens did in "kickstart v2", what he called
> "k2", in the VDS CVS.  It had conventions to deal with passing args in a
> file stream rather than command line to tunnel through what at the time
> were cli length limits and arg escape problems in Condor
We should try not to make the wrapper a bad substitute for a bad job
manager. In other words I don't think it should fix too many problems.
> I feel this merits a design effort, and propose that we try this as an
> experiment in doing design in a way that can get group input do decision
> making in an effective and pleasing way.
So we should first decide what we're talking about:
1. Logging of application stuff (i.e. providing information similar to
kickstart)
2. Fixin' problems in Condor and GRAM
I think it should only be a focused thing around (1).
