[Swift-devel] Drop kickstart, adopt wrapper logs?
    Ian Foster
    foster at mcs.anl.gov
    Fri Jul 25 08:20:43 CDT 2008
Mike:
There was an agreement a year or more ago that the VDS group would
work with the GRAM team on integration. I suspect it got dropped, but
I wanted to check.
Ian.
On Jul 25, 2008, at 8:17 AM, Michael Wilde wrote:
> Im not aware of any work done in that direction.
> I would have to hunt back through emails for the last thing we said
> we would do.
> Its been an often discussed topic, but one thats hard to move
> forward on.
> The tradeoff is doing something that works well for swift, vs having
> a significantly larger and longer discussion on what would work for
> GRAM as well (and potentially Condor and ...)
> One possibility is that we stay with a kickstart like architecture
> where kickstart is the last thing called to launch the app, and that
> becomes a separable component that can be used elsewhere. We do it
> in a way that its useful with GRAM and other systems, and which
> users can just use.
> Then the discussion becomes mostly one of data format.
> There the two likely candidates are XML or name/value pairs,
> possibly in some other "standard" format, eg classads.
> Another possibility is to emit an xml doc in a rigid format that
> doesnt need an xml parser to process it - sort of n/v pairs in xml.
> This gets complicated with multiline and escape issues of course.
> Its worth a chat with the GRAM team.  It will be a slower harder
> route though.  Thats a tradeoff.
> - Mike
> On 7/25/08 8:01 AM, Ian Foster wrote:
>> Mike:
>> What is the status of the integration into kickstart into the
>> Globus release?
>> Ian.
>> On Jul 25, 2008, at 7:41 AM, Michael Wilde wrote:
>>> was: Re: Can we copy Swift execution logs to CI network?
>>> Should we make this transition, dropping kickstart, and making the
>>> wrapper log a useful format that becomes part of the Swift runtime
>>> specification?
>>> On 7/15/08 4:18 PM, Ben Clifford wrote:
>>> <snip>
>>>> ...there's substantial lack of information
>>>> for many runs as we have been tweaking the logs over time
>>>> (especially the worker node logs which take a similar place to
>>>> kickstart records now - giving the actual on-worker cpu usage but
>>>> are relatively very expensive to collect and move around).
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
