[Swift-devel] Drop kickstart, adopt wrapper logs?
    Michael Wilde
    wilde at mcs.anl.gov
    Fri Jul 25 08:17:39 CDT 2008
Im not aware of any work done in that direction.
I would have to hunt back through emails for the last thing we said we
would do.
Its been an often discussed topic, but one thats hard to move forward on.
The tradeoff is doing something that works well for swift, vs having a
significantly larger and longer discussion on what would work for GRAM
as well (and potentially Condor and ...)
One possibility is that we stay with a kickstart like architecture where
kickstart is the last thing called to launch the app, and that becomes a
separable component that can be used elsewhere. We do it in a way that
its useful with GRAM and other systems, and which users can just use.
Then the discussion becomes mostly one of data format.
There the two likely candidates are XML or name/value pairs, possibly in
some other "standard" format, eg classads.
Another possibility is to emit an xml doc in a rigid format that doesnt
need an xml parser to process it - sort of n/v pairs in xml. This gets
complicated with multiline and escape issues of course.
Its worth a chat with the GRAM team.  It will be a slower harder route
though.  Thats a tradeoff.
- Mike
On 7/25/08 8:01 AM, Ian Foster wrote:
> Mike:
> What is the status of the integration into kickstart into the Globus
> release?
> Ian.
> On Jul 25, 2008, at 7:41 AM, Michael Wilde wrote:
>> was: Re: Can we copy Swift execution logs to CI network?
>> Should we make this transition, dropping kickstart, and making the
>> wrapper log a useful format that becomes part of the Swift runtime
>> specification?
>> On 7/15/08 4:18 PM, Ben Clifford wrote:
>> <snip>
>>> ...there's substantial lack of information
>>> for many runs as we have been tweaking the logs over time (especially
>>> the worker node logs which take a similar place to kickstart records
>>> now - giving the actual on-worker cpu usage but are relatively very
>>> expensive to collect and move around).
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
