[Swift-devel] Re: 2 rack run with swift
Michael Wilde
wilde at mcs.anl.gov
Thu Jul 24 09:50:30 CDT 2008
On 7/24/08 9:24 AM, Ioan Raicu wrote:
> Hi,
> I did a similar run through Falkon only, and got:
> Number of Tasks: 16384
> Task Duration: 30 sec
> Average Task Execution Time (from Client point of view): 31.851 sec
> Number of CPUs: 8192
> Startup: 5.185 sec
> Execute: 80.656 sec
> Ideal time: 60 sec
> Swift took some 600 seconds, and had an average per task run time of
> 240.97 sec. Zhao, was Swift patched up, with Ben's 3 patches from
> April/May?
No. But one or more of those patches may have been integrated into the
source. Still needs to be enabled. We'll look into this more in the
next few days. I dont want to spend much time discussing this, though,
until we have a chance to sort through all the issues we already know
about: scheduler parameters, data management, wrapper script settings
and patches, GPFS issues.
Tests at longer job durations are worth doing.
- Mike
I am curious what would happen if we throw 256 second tasks
> through Swift, at the same 2 rack scale?
> Ioan
> Michael Wilde wrote:
>> Thanks, Zhao,
>> This is a great initial snapshot of performance on the new BG/P Falkon
>> server mechanism (1 server per pset).
>> Its also the largest Swift run to date I know of in terms of "sites"
>> (32) and processors used (8192).
>> From a quick scan of the plots, it seems like we have some tuning to do:
>> The ideal time for this run would be 120 seconds. It took 600 seconds.
>> Thats in fact "not bad at all" for a first attempt at this scale, and
>> very reasonable if the job length were longer. 16K jobs in 10 minutes
>> is pretty good. The nearest real-world Falkon-only run I can compare
>> to is the 15Kx9 DOCK run, which did 138K jobs in 40 minutes. This run
>> performed at somewhat under half that rate.
>> I suspect that the main bottleneck this is hitting is creation of job
>> directories on the BGP. As we learned in the past few months of
>> Falkon-only runs, creation of filesystem objects on GPFS is very
>> expensive, and creation of two objects within the same parent
>> directory by > 1 host is extremely expensive in locking contention.
>> I *think* the plots bear this out, but need more assessment.
>> I'd like to start by writing down a detailed description of the
>> runtime file environment and management logic (i.e. job setup by swift
>> and file management by wrapper.sh. Then look to see which of the
>> options Ben provided when we last did this, in March, were properly
>> enabled. (Some may still be un-applied test patches). Then turn on
>> some of the timing metrics in wrapper.sh to see where time is spent.
>> I also see that job distribution among servers is pretty good -
>> ranging from 490 to 600 jobs, but for the most part staying within 10
>> jobs of the ideal, 512.
>> I can't work on this today till our Swift report is done, but can then
>> turn to it. Ben, once you're done with the SA Grid School, we could
>> use your help on this. Mihael, as well, if you're interested and able
>> to help.
>> For now, I think we know a few steps we can take to measure and
>> improve things.
>> - Mike
>> On 7/24/08 1:19 AM, Zhao Zhang wrote:
>>> Hi, All
>>> I just made a swift run of 16384 sleep_30 tasks on 2 racks, which are
>>> 8192 cores. The log is at
>>> http://www.ci.uchicago.edu/~zzhang/report-sleep-20080724-0030-3zbv20j6/
>>> Tomorrow, I will try to make a mars run with swift.
>>> zhao
