[Swift-devel] Question for running swift with 2 psets on BGP
Zhao Zhang
zhaozhang at uchicago.edu
Tue Jul 22 16:00:46 CDT 2008
ok, I removed the "static" in the line Mihael pointed out. And recompile
it, got the following.
zhao
compile:
[echo] [provider-deef]: COMPILE
[mkdir] Created dir: /gpfs/home/falkon/cog/modules/provider-deef/build
[javac] Compiling 8 source files to
[javac]
/gpfs/home/falkon/cog/modules/provider-deef/src/org/globus/cog/abstraction/impl/execution/deef/JobSubmissionTaskHandler.java:157:
non-static method instance(java.lang.String,int) cannot be referenced
from a static context
[javac] resourcePool = ResourcePool.instance(server, 1);
[javac] ^
[javac] Note:
uses or overrides a deprecated API.
[javac] Note: Recompile with -deprecation for details.
[javac] 1 error
Ioan Raicu wrote:
> Right, that the "static" declaration would certainly cause trouble :(
> I don't recall why we made it static, perhaps its simply old code that
> was never updated, Zhao, can you simply remove the static declaration,
> and see if it still compiles, and if yes, try it out?
> Ioan
> Mihael Hategan wrote:
>> I'd look here:
>> public static synchronized ResourcePool instance(String server, int num)
>> throws InvalidServiceContactException {
>> if (rp == null) {
>> rp = new ResourcePool();
>> On Tue, 2008-07-22 at 15:32 -0500, Michael Wilde wrote:
>>> Zhao's renaming the sites to avoid any substring problem.
>>> The current data shows a contradiction, though: the stats plot shows
>>> nice balancing between sites, but the falkon logs think all traffic went
>>> to one site.
>>> If the next run shows same, I think we need to a) look in the Swift log
>>> and site selection info and b) double check that the two falkon servers
>>> are not logging to (or listening to) the same place.
>>> - Mike
>>> On 7/22/08 3:28 PM, Mihael Hategan wrote:
>>>> On Tue, 2008-07-22 at 15:20 -0500, Ioan Raicu wrote:
>>>>> So, are you saying that it did work as expected, and it load balanced
>>>>> across the two sites?
>>>> Pretty much, yes.
>>>>> Who assigns the names "bgps" and "bgps1"?
>>>> In this case it would be Zhao.
>>>>> If its the user (i.e. Zhao :), then should we name these strings
>>>>> better?
>>>> I suppose using bgps1 and bgps2 would prevent the triggering of that bug
>>>> in the stats scripts.
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu
> Ph.D. Candidate
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web: http://www.cs.uchicago.edu/~iraicu
> http://dev.globus.org/wiki/Incubator/Falkon
> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
