[Swift-devel] Question for running swift with 2 psets on BGP
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Tue Jul 22 15:37:03 CDT 2008
Right, that the "static" declaration would certainly cause trouble :(  I
don't recall why we made it static, perhaps its simply old code that was
never updated, Zhao, can you simply remove the static declaration, and
see if it still compiles, and if yes, try it out?
Ioan
Mihael Hategan wrote:
> I'd look here:
> public static synchronized ResourcePool instance(String server, int num)
> throws InvalidServiceContactException {
>         if (rp == null) {
>             rp = new ResourcePool();
> On Tue, 2008-07-22 at 15:32 -0500, Michael Wilde wrote:
>> Zhao's renaming the sites to avoid any substring problem.
>> The current data shows a contradiction, though: the stats plot shows
>> nice balancing between sites, but the falkon logs think all traffic went
>> to one site.
>> If the next run shows same, I think we need to a) look in the Swift log
>> and site selection info and b) double check that the two falkon servers
>> are not logging to (or listening to) the same place.
>> - Mike
>> On 7/22/08 3:28 PM, Mihael Hategan wrote:
>>> On Tue, 2008-07-22 at 15:20 -0500, Ioan Raicu wrote:
>>>> So, are you saying that it did work as expected, and it load balanced
>>>> across the two sites?
>>> Pretty much, yes.
>>>>   Who assigns the names "bgps" and "bgps1"?
>>> In this case it would be Zhao.
>>>>   If its the user (i.e. Zhao :),  then should we name these strings
>>>> better?
>>> I suppose using bgps1 and bgps2 would prevent the triggering of that bug
>>> in the stats scripts.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080722/bc719bb5/attachment.html>
