[Swift-devel] Re: scheduler foo
Mihael Hategan
hategan at mcs.anl.gov
Mon Jul 21 09:30:59 CDT 2008
On Mon, 2008-07-21 at 13:14 +0000, Ben Clifford wrote:
> poking more at this. the approach used in the code at the moment seems to
> have a few problems:
> The frist, in situations like the below code fragment the first
> overloadedCount adjustment
> takes away the overloadedness of the host in question, then adds the new
> overloadedness back. However, it relies on the first checkOverloaded
> returning the (negative of the) same as what has been added previously -
> either by a previous checkOverloaded call or by a timer thread.
> This seems to not always happen.
> overloadedCount += checkOverloaded(wh, -1);
> wh.setScore(newScore);
> weightedHosts.put(wh.getHost(), wh);
> scores.add(wh);
> sum += wh.getTScore();
> overloadedCount += checkOverloaded(wh, 1);
> Secondly timer tasks are not killed, so a large number of timer tasks get
> started up for overloaded sites.
Oh, I see. They are started multiple times for the same delay.
> This appears to cause some weird
> behaviour.
> I've put commits in that tidy up a few apparent bugs a bit but the
> abovementioned behaviour remains. It seems difficult to deal with the
> above in an o(1) fashion - if moving away from that, an explicit check of
> each site's overload status (as implemented in the previous patches on
> this thread) appears to work.
