[Swift-devel] Support request: Swift jobs flooding uc-teragrid?
    Ian Foster
    foster at mcs.anl.gov
    Tue Jan 29 13:15:51 CST 2008
I've CCed Stuart Martin--I'd greatly appreciate some insights into what
is causing this. I assume that you are using GRAM4 (aka WS-GRAM)?
Ian.
Michael Wilde wrote:
> [ was Re: Swift jobs on UC/ANL TG ]
> Hi. Im at OHare and will be flying soon.
> Ben or Mihael, if you are online, can you investigate?
> Yes, there are significant throttles turned on by default, and the
> system opens those very gradually.
> MikeK, can you post to the swift-devel list your swift.properties
> file, command line options, and your swift source code?
> Thanks,
> MikeW
> On 1/29/08 8:11 AM, Ti Leggett wrote:
>> The default walltime is 15 minutes. Are you doing fork jobs or pbs
>> jobs? You shouldn't be doing fork jobs at all. Mike W, I thought
>> there were throttles in place in Swift to prevent this type of
>> overrun? Mike K, I'll need you to either stop these types of jobs
>> until Mike W can verify throttling or only submit a few 10s of jobs
>> at a time.
>> On Jan 28, 2008, at 01/28/08 07:13 PM, Mike Kubal wrote:
>>> Yes, I'm submitting molecular dynamics simulations
>>> using Swift.
>>> Is there a default wall-time limit for jobs on tg-uc?
>>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>>> Actually, these numbers are now escalating...
>>>> top - 17:18:54 up  2:29,  1 user,  load average:
>>>> 149.02, 123.63, 91.94
>>>> Tasks: 469 total,   4 running, 465 sleeping,   0
>>>> stopped,   0 zombie
>>>> insley at tg-grid1:~> ps -ef | grep kubal | wc -l
>>>>     479
>>>> insley at tg-viz-login1:~> time globusrun -a -r
>>>> tg-grid.uc.teragrid.org
>>>> GRAM Authentication test successful
>>>> real    0m26.134s
>>>> user    0m0.090s
>>>> sys     0m0.010s
>>>> On Jan 28, 2008, at 5:15 PM, joseph insley wrote:
>>>>> Earlier today tg-grid.uc.teragrid.org (the UC/ANL
>>>> TG GRAM host)
>>>>> became unresponsive and had to be rebooted.  I am
>>>> now seeing slow
>>>>> response times from the Gatekeeper there again.
>>>> Authenticating to
>>>>> the gatekeeper should only take a second or two,
>>>> but it is
>>>>> periodically taking up to 16 seconds:
>>>>> real    0m16.096s
>>>>> user    0m0.060s
>>>>> sys     0m0.020s
>>>>> looking at the load on tg-grid, it is rather high:
>>>>> top - 16:55:26 up  2:06,  1 user,  load average:
>>>> 89.59, 78.69, 62.92
>>>>> Tasks: 398 total,  20 running, 378 sleeping,   0
>>>> stopped,   0 zombie
>>>>> And there appear to be a large number of processes
>>>> owned by kubal:
>>>>>    380
>>>>> I assume that Mike is using swift to do the job
>>>> submission.  Is
>>>>> there some throttling of the rate at which jobs
>>>> are submitted to
>>>>> the gatekeeper that could be done that would
>>>> lighten this load
>>>>> some?  (Or has that already been done since
>>>> earlier today?)  The
>>>>> current response times are not unacceptable, but
>>>> I'm hoping to
>>>>> avoid having the machine grind to a halt as it did
>>>> earlier today.
>>>>> Thanks,
>>>>> joe.
>>>>> joseph a.
>>>>> insley
>>>>> mathematics & computer science division
>>>> (630) 252-5649
>>>>> argonne national laboratory
>>>>       (630)
>>>>> 252-5986 (fax)
>>>> joseph a. insley
>>>> mathematics & computer science division       (630)
>>>> 252-5649
>>>>     (630)
>>>> 252-5986 (fax)
>>> ____________________________________________________________________________________
>>> Be a better friend, newshound, and
>>> know-it-all with Yahoo! Mobile.  Try it now.
>>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
