[Swift-devel] Support request: Swift jobs flooding uc-teragrid?
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jan 29 10:11:51 CST 2008
[ was Re: Swift jobs on UC/ANL TG ]
Hi. Im at OHare and will be flying soon.
Ben or Mihael, if you are online, can you investigate?
Yes, there are significant throttles turned on by default, and the
system opens those very gradually.
MikeK, can you post to the swift-devel list your swift.properties file,
command line options, and your swift source code?
MikeW
On 1/29/08 8:11 AM, Ti Leggett wrote:
> The default walltime is 15 minutes. Are you doing fork jobs or pbs jobs?
> You shouldn't be doing fork jobs at all. Mike W, I thought there were
> throttles in place in Swift to prevent this type of overrun? Mike K,
> I'll need you to either stop these types of jobs until Mike W can verify
> throttling or only submit a few 10s of jobs at a time.
> On Jan 28, 2008, at 01/28/08 07:13 PM, Mike Kubal wrote:
>> Yes, I'm submitting molecular dynamics simulations
>> using Swift.
>> Is there a default wall-time limit for jobs on tg-uc?
>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>> Actually, these numbers are now escalating...
>>> top - 17:18:54 up  2:29,  1 user,  load average:
>>> 149.02, 123.63, 91.94
>>> Tasks: 469 total,   4 running, 465 sleeping,   0
>>> stopped,   0 zombie
>>> insley at tg-grid1:~> ps -ef | grep kubal | wc -l
>>>     479
>>> insley at tg-viz-login1:~> time globusrun -a -r
>>> tg-grid.uc.teragrid.org
>>> GRAM Authentication test successful
>>> real    0m26.134s
>>> user    0m0.090s
>>> sys     0m0.010s
>>> On Jan 28, 2008, at 5:15 PM, joseph insley wrote:
>>>> Earlier today tg-grid.uc.teragrid.org (the UC/ANL
>>> TG GRAM host)
>>>> became unresponsive and had to be rebooted.  I am
>>> now seeing slow
>>>> response times from the Gatekeeper there again.
>>> Authenticating to
>>>> the gatekeeper should only take a second or two,
>>> but it is
>>>> periodically taking up to 16 seconds:
>>>> real    0m16.096s
>>>> user    0m0.060s
>>>> sys     0m0.020s
>>>> looking at the load on tg-grid, it is rather high:
>>>> top - 16:55:26 up  2:06,  1 user,  load average:
>>> 89.59, 78.69, 62.92
>>>> Tasks: 398 total,  20 running, 378 sleeping,   0
>>> stopped,   0 zombie
>>>> And there appear to be a large number of processes
>>> owned by kubal:
>>>>    380
>>>> I assume that Mike is using swift to do the job
>>> submission.  Is
>>>> there some throttling of the rate at which jobs
>>> are submitted to
>>>> the gatekeeper that could be done that would
>>> lighten this load
>>>> some?  (Or has that already been done since
>>> earlier today?)  The
>>>> current response times are not unacceptable, but
>>> I'm hoping to
>>>> avoid having the machine grind to a halt as it did
>>> earlier today.
>>>> Thanks,
>>>> joe.
>>>> joseph a.
>>>> insley
>>>> mathematics & computer science division
>>> (630) 252-5649
>>>> argonne national laboratory
>>>       (630)
>>>> 252-5986 (fax)
>>> joseph a. insley
>>> mathematics & computer science division       (630)
>>> 252-5649
>>>     (630)
>>> 252-5986 (fax)
>> ____________________________________________________________________________________
>> Be a better friend, newshound, and
>> know-it-all with Yahoo! Mobile.  Try it now.
>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
