[Swift-devel] cog r1871
    feller at mcs.anl.gov
    Thu Feb 21 13:32:29 CST 2008
99.63% sure that it was built with java 1.4
if it was 1.5 a client running under 1.4 should see errors.
Martin
> An email message in a different thread brings the question: is this
> compiled for 1.4 or 1.5?
> Mihael
> On Mon, 2008-02-11 at 23:28 -0600, feller at mcs.anl.gov wrote:
>> My fault, not the ObjectSerializers one.
>> You submitted in batch-mode?
>> The attached jar should fix that.
>> Hope the java version is fine.
>> Martin
>> > Martin?
>> > On Mon, 2008-02-11 at 22:50 +0000, Ben Clifford wrote:
>> >> I'm seeing repeatable cleanup errors like the below. The workflows
>> run
>> >> to
>> >> completion, though.
>> >> RunID: 20080211-2248-rsqe1da0
>> >> cat started
>> >> cat completed
>> >> The following warnings have occurred:
>> >> 1. Cleanup on tguc failed
>> >> Caused by:
>> >>         Cannot submit job: null
>> >> Caused by:
>> >>         java.lang.NullPointerException
>> >>         at
>> >> org.globus.wsrf.encoding.ObjectSerializer.clone(ObjectSerializer.java:211)
>> >>         at
>> >> org.globus.exec.client.GramJob.createJobEndpoint(GramJob.java:970)
>> >>         at org.globus.exec.client.GramJob.submit(GramJob.java:447)
>> >>         at
>> >> org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:189)
>> >>         at
>> >> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
>> >>         at
>> >> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:86)
>> >>         at
>> >> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
