[Swift-devel] cog r1871
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Feb 21 12:53:25 CST 2008
An email message in a different thread brings the question: is this
compiled for 1.4 or 1.5?
Mihael
On Mon, 2008-02-11 at 23:28 -0600, feller at mcs.anl.gov wrote:
> My fault, not the ObjectSerializers one.
> You submitted in batch-mode?
> The attached jar should fix that.
> Hope the java version is fine.
> Martin
> > Martin?
> > On Mon, 2008-02-11 at 22:50 +0000, Ben Clifford wrote:
> >> I'm seeing repeatable cleanup errors like the below. The workflows run
> >> to
> >> completion, though.
> >> RunID: 20080211-2248-rsqe1da0
> >> cat started
> >> cat completed
> >> The following warnings have occurred:
> >> 1. Cleanup on tguc failed
> >> Caused by:
> >>         Cannot submit job: null
> >> Caused by:
> >>         java.lang.NullPointerException
> >>         at
> >> org.globus.wsrf.encoding.ObjectSerializer.clone(ObjectSerializer.java:211)
> >>         at
> >> org.globus.exec.client.GramJob.createJobEndpoint(GramJob.java:970)
> >>         at org.globus.exec.client.GramJob.submit(GramJob.java:447)
> >>         at
> >> org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:189)
> >>         at
> >> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
> >>         at
> >> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:86)
> >>         at
> >> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
