[Swift-devel] Re: Swift jobs on UC/ANL TG
Mihael Hategan hategan at mcs.anl.gov
Sun Feb 3 21:16:05 CST 2008
On Sun, 2008-02-03 at 21:12 -0600, Ian Foster wrote:
> Mihael:
> Is there any chance you can try GRAM4, as was requested early last
> week?
For the tests, sure. That's a big part of why I'm doing them.
If we're talking about the workflow that seems to be repeatedly killing
tg-grid1, then Mike Kubal would be the right person to ask.
> Ian.
> Mihael Hategan wrote:
> > So I was trying some stuff on Friday night. I guess I've found the
> > strategy on when to run the tests: when nobody else has jobs there
> > (besides Buzz doing gridftp tests, Ioan having some Falkon workers
> > running, and the occasional Inca tests).
> > In any event, the machine jumps to about 100% utilization at around 130
> > jobs with pre-ws gram. So Mike, please set throttle.score.job.factor to
> > 1 in swift.properties.
> > There's still more work I need to do test-wise.
> > On Sun, 2008-02-03 at 15:34 -0600, Ti Leggett wrote:
> > > Mike, You're killing tg-grid1 again. Can someone work with Mike to get
> > > some swift settings that don't kill our server?
> > > On Jan 28, 2008, at 7:13 PM, Mike Kubal wrote:
> > > > Yes, I'm submitting molecular dynamics simulations
> > > > using Swift.
> > > > Is there a default wall-time limit for jobs on tg-uc?
> > > > --- joseph insley <insley at mcs.anl.gov> wrote:
> > > > > Actually, these numbers are now escalating...
> > > > > top - 17:18:54 up  2:29,  1 user,  load average:
> > > > > 149.02, 123.63, 91.94
> > > > > Tasks: 469 total,   4 running, 465 sleeping,   0
> > > > > stopped,   0 zombie
> > > > > insley at tg-grid1:~> ps -ef | grep kubal | wc -l
> > > > >     479
> > > > > insley at tg-viz-login1:~> time globusrun -a -r
> > > > > tg-grid.uc.teragrid.org
> > > > > GRAM Authentication test successful
> > > > > real    0m26.134s
> > > > > user    0m0.090s
> > > > > sys     0m0.010s
> > > > > On Jan 28, 2008, at 5:15 PM, joseph insley wrote:
> > > > > > Earlier today tg-grid.uc.teragrid.org (the UC/ANL
> > > > > TG GRAM host)
> > > > > > became unresponsive and had to be rebooted.  I am
> > > > > now seeing slow
> > > > > > response times from the Gatekeeper there again.
> > > > > Authenticating to
> > > > > > the gatekeeper should only take a second or two,
> > > > > but it is
> > > > > > periodically taking up to 16 seconds:
> > > > > > real    0m16.096s
> > > > > > user    0m0.060s
> > > > > > sys     0m0.020s
> > > > > > looking at the load on tg-grid, it is rather high:
> > > > > > top - 16:55:26 up  2:06,  1 user,  load average:
> > > > > 89.59, 78.69, 62.92
> > > > > > Tasks: 398 total,  20 running, 378 sleeping,   0
> > > > > stopped,   0 zombie
> > > > > > And there appear to be a large number of processes
> > > > > owned by kubal:
> > > > > >    380
> > > > > > I assume that Mike is using swift to do the job
> > > > > submission.  Is
> > > > > > there some throttling of the rate at which jobs
> > > > > are submitted to
> > > > > > the gatekeeper that could be done that would
> > > > > lighten this load
> > > > > > some?  (Or has that already been done since
> > > > > earlier today?)  The
> > > > > > current response times are not unacceptable, but
> > > > > I'm hoping to
> > > > > > avoid having the machine grind to a halt as it did
> > > > > earlier today.
> > > > > > Thanks,
> > > > > > joe.
> > > > > > joseph a.
> > > > > > insley
> > > > > > mathematics & computer science division
> > > > > (630) 252-5649
> > > > > > argonne national laboratory
> > > > > (630)
> > > > > > 252-5986 (fax)
> > > > > joseph a. insley
> > > > > mathematics & computer science division       (630)
> > > > > 252-5649
> > > > >     (630)
> > > > > 252-5986 (fax)
> > > > ____________________________________________________________________________________
> > > > Be a better friend, newshound, and
> > > > know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
