[Swift-devel] ssh data provider
Zhao Zhang
zhaozhang at uchicago.edu
Thu Dec 11 21:12:45 CST 2008
sure, http://www.ci.uchicago.edu/~zzhang/first-20081211-2021-oi8c3r0b.log
zhao
Mihael Hategan wrote:
> Ok. Can you paste a link to the log file?
> On Thu, 2008-12-11 at 20:57 -0600, Zhao Zhang wrote:
>> I tried to run sftp on IO nodes,
>> bash-3.1$ sftp
>> usage: sftp [-1Cv] [-B buffer_size] [-b batchfile] [-F ssh_config]
>> [-o ssh_option] [-P sftp_server_path] [-R num_requests]
>> [-S program] [-s subsystem | sftp_server] host
>> sftp [[user@]host[:file [file]]]
>> sftp [[user@]host[:dir[/]]]
>> sftp -b batchfile [user@]host
>> it seems that there is a working version
>> zhao
>>> You could ask the folks who administer the BG to enable sftp on the io
>>> nodes. This is enabled by default with openssh.
>>> On Thu, 2008-12-11 at 20:52 -0600, Zhao Zhang wrote:
>>>> got this
>>>> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
>>>> -tc.file ./tc.data first.swift
>>>> Swift svn swift-r2334 (Swift modified locally) cog-r2216
>>>> RunID: 20081211-2021-oi8c3r0b
>>>> Progress:
>>>> echo started
>>>> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
>>>> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
>>>> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
>>>> echo failed
>>>> Execution failed:
>>>> Could not initialize shared directory on bgp000
>>>> Caused by:
>>>> org.globus.cog.abstraction.impl.file.FileResourceException:
>>>> Error while communicating with the SSH server on 172.16.3.2:22
>>>> Caused by:
>>>> Failed to start the SFTP subsystem on zzhang:<key>@172.16.3.2:22
>>>>> now try swift
>>>>>>> On Thu, 2008-12-11 at 20:00 -0600, Zhao Zhang wrote:
>>>>>>>> nope, we don't need to since ssh works for us.
>>>>>>> Mmm, obviously not. May I suggest typing "man ssh" and reading the
>>>>>>> section on authentication?
>>>>>> By "it works" I mean it works for our ordinary use, we could login IO
>>>>>> nodes with that host based authentication.
>>>>>>>> Besides, I have no idea
>>>>>>>> where the ssh on IO nodes saves the public key.
>>>>>>> For public key authentication you need to put the public
>>>>>>> key (~/.ssh/id_rsa.pub) in ~/.ssh/authorized_keys on the remote
>>>>>>> machine. This is the public key that corresponds to your private key.
>>>>>> Ha, it works now.
>>>>>> zzhang at login6.surveyor:~/swift/test> ssh -v -o
>>>>>> HostbasedAuthentication=no -l zzh
>>>>>> ang -i /home/zzhang/.ssh/id_rsa ion-1
>>>>>> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
>>>>>> debug1: Reading configuration data /etc/ssh/ssh_config
>>>>>> debug1: Applying options for *
>>>>>> debug1: /etc/ssh/ssh_config line 25: Deprecated option
>>>>>> "RhostsAuthentication"
>>>>>> debug1: Connecting to ion-1 [172.16.3.1] port 22.
>>>>>> debug1: Connection established.
>>>>>> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
>>>>>> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
>>>>>> debug1: match: OpenSSH_4.2 pat OpenSSH*
>>>>>> debug1: Enabling compatibility mode for protocol 2.0
>>>>>> debug1: Local version string SSH-2.0-OpenSSH_4.2
>>>>>> debug1: SSH2_MSG_KEXINIT sent
>>>>>> debug1: SSH2_MSG_KEXINIT received
>>>>>> debug1: kex: server->client aes128-cbc hmac-md5 none
>>>>>> debug1: kex: client->server aes128-cbc hmac-md5 none
>>>>>> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
>>>>>> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
>>>>>> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
>>>>>> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
>>>>>> debug1: Host 'ion-1' is known and matches the RSA host key.
>>>>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:40
>>>>>> Warning: the RSA host key for 'ion-1' differs from the key for the IP
>>>>>> address '172.16.3.1'
>>>>>> Offending key for IP in /home/zzhang/.ssh/known_hosts:3
>>>>>> Matching host key in /home/zzhang/.ssh/known_hosts:40
>>>>>> debug1: ssh_rsa_verify: signature correct
>>>>>> debug1: SSH2_MSG_NEWKEYS sent
>>>>>> debug1: expecting SSH2_MSG_NEWKEYS
>>>>>> debug1: SSH2_MSG_NEWKEYS received
>>>>>> debug1: SSH2_MSG_SERVICE_REQUEST sent
>>>>>> debug1: SSH2_MSG_SERVICE_ACCEPT received
>>>>>> debug1: Authentications that can continue:
>>>>>> publickey,keyboard-interactive,hostbased
>>>>>> debug1: Next authentication method: publickey
>>>>>> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
>>>>>> debug1: Server accepts key: pkalg ssh-rsa blen 277
>>>>>> debug1: read PEM private key done: type RSA
>>>>>> debug1: Authentication succeeded (publickey).
>>>>>> debug1: channel 0: new [client-session]
>>>>>> debug1: Entering interactive session.
>>>>>> Last login: Thu Dec 11 20:15:10 2008 from login6-data.surveyor.alcf.anl.gov
>>>>>> BusyBox v1.4.2 (2008-05-07 02:58:20 UTC) Built-in shell (ash)
>>>>>> Enter 'help' for a list of built-in commands.
>>>>>> /gpfs/home/zzhang $
>>>>>>>> zhao
>>>>>>>>> Have you installed the public key on ion-1?
>>>>>>>>> On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
>>>>>>>>>> Then it failed
>>>>>>>>>> ang -i /home/zzhang/.ssh/id_rsa ion-7
>>>>>>>>>> debug1: Connecting to ion-7 [172.16.3.7] port 22.
>>>>>>>>>> debug1: Host 'ion-7' is known and matches the RSA host key.
>>>>>>>>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
>>>>>>>>>> debug1: Next authentication method: keyboard-interactive
>>>>>>>>>> debug1: No more authentication methods to try.
>>>>>>>>>> Permission denied (publickey,keyboard-interactive,hostbased).
>>>>>>>>>>> I looked at the ssh logs, and it seems like you're logging in using
>>>>>>>>>>> hostbased authentication.
>>>>>>>>>>> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
>>>>>>>>>>> Also, note that you misspelled "id_rsa": Warning: Identity
>>>>>>>>>>> file /home/zzhang/.ssh/ir_rsa not accessible: No such
>>>>>>>>>>> file or directory.
>>>>>>>>>>> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
>>>>>>>>>>>> Ha, you are right, i put a wrong log here.
>>>>>>>>>>>> I rerun it, if failed with the following message.
>>>>>>>>>>>> RunID: 20081211-1850-rcrr2fk0
>>>>>>>>>>>> Progress:
>>>>>>>>>>>> echo started
>>>>>>>>>>>> echo failed
>>>>>>>>>>>> Execution failed:
>>>>>>>>>>>> Caused by:
>>>>>>>>>>>> Error while communicating with the SSH server on 172.16.3.7:22
>>>>>>>>>>>> Caused by:
>>>>>>>>>>>> Public Key Authentication failed
>>>>>>>>>>>> zhao
>>>>>>>>>>>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
>>>>>>>>>>>>>> sure, it is 172.16.3.6.passphrase=
>>>>>>>>>>>>> I don't believe you. Can you paste the file?
>>>>>>>>>>>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
>>>>>>>>>>>>>>>> Hi, Mihael
>>>>>>>>>>>>>>>> If I put .passphrase= there, I got this:
>>>>>>>>>>>>>>> With the IP address before .passphrase, of course. I.e.
