[Swift-devel] ssh data provider
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Dec 11 21:00:44 CST 2008
Ok. Can you paste a link to the log file?
On Thu, 2008-12-11 at 20:57 -0600, Zhao Zhang wrote:
> I tried to run sftp on IO nodes,
> bash-3.1$ sftp
> usage: sftp [-1Cv] [-B buffer_size] [-b batchfile] [-F ssh_config]
>             [-o ssh_option] [-P sftp_server_path] [-R num_requests]
>             [-S program] [-s subsystem | sftp_server] host
>        sftp [[user@]host[:file [file]]]
>        sftp [[user@]host[:dir[/]]]
>        sftp -b batchfile [user@]host
> it seems that there is a working version
> zhao
> Mihael Hategan wrote:
> > You could ask the folks who administer the BG to enable sftp on the io
> > nodes. This is enabled by default with openssh.
> > On Thu, 2008-12-11 at 20:52 -0600, Zhao Zhang wrote:
> >> got this
> >> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
> >> -tc.file ./tc.data first.swift
> >> Swift svn swift-r2334 (Swift modified locally) cog-r2216
> >> RunID: 20081211-2021-oi8c3r0b
> >> Progress:
> >> echo started
> >> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
> >> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
> >> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
> >> echo failed
> >> Execution failed:
> >>         Could not initialize shared directory on bgp000
> >> Caused by:
> >>         org.globus.cog.abstraction.impl.file.FileResourceException:
> >> Error while communicating with the SSH server on 172.16.3.2:22
> >> Caused by:
> >>         Failed to start the SFTP subsystem on zzhang:<key>@172.16.3.2:22
> >>> now try swift
> >>>>> On Thu, 2008-12-11 at 20:00 -0600, Zhao Zhang wrote:
> >>>>>> nope, we don't need to since ssh works for us.
> >>>>> Mmm, obviously not. May I suggest typing "man ssh" and reading the
> >>>>> section on authentication?
> >>>> By "it works" I mean it works for our ordinary use, we could login IO
> >>>> nodes with that host based authentication.
> >>>>>>  Besides, I have no idea
> >>>>>> where the ssh on IO nodes saves the public key.
> >>>>> For public key authentication you need to put the public
> >>>>> key (~/.ssh/id_rsa.pub) in ~/.ssh/authorized_keys on the remote
> >>>>> machine. This is the public key that corresponds to your private key.
> >>>> Ha, it works now.
> >>>> zzhang at login6.surveyor:~/swift/test> ssh -v -o
> >>>> HostbasedAuthentication=no -l zzh
> >>>> ang -i /home/zzhang/.ssh/id_rsa ion-1
> >>>> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
> >>>> debug1: Reading configuration data /etc/ssh/ssh_config
> >>>> debug1: Applying options for *
> >>>> debug1: /etc/ssh/ssh_config line 25: Deprecated option
> >>>> "RhostsAuthentication"
> >>>> debug1: Connecting to ion-1 [172.16.3.1] port 22.
> >>>> debug1: Connection established.
> >>>> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
> >>>> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
> >>>> debug1: match: OpenSSH_4.2 pat OpenSSH*
> >>>> debug1: Enabling compatibility mode for protocol 2.0
> >>>> debug1: Local version string SSH-2.0-OpenSSH_4.2
> >>>> debug1: SSH2_MSG_KEXINIT sent
> >>>> debug1: SSH2_MSG_KEXINIT received
> >>>> debug1: kex: server->client aes128-cbc hmac-md5 none
> >>>> debug1: kex: client->server aes128-cbc hmac-md5 none
> >>>> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
> >>>> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
> >>>> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
> >>>> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
> >>>> debug1: Host 'ion-1' is known and matches the RSA host key.
> >>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:40
> >>>> Warning: the RSA host key for 'ion-1' differs from the key for the IP
> >>>> address '172.16.3.1'
> >>>> Offending key for IP in /home/zzhang/.ssh/known_hosts:3
> >>>> Matching host key in /home/zzhang/.ssh/known_hosts:40
> >>>> debug1: ssh_rsa_verify: signature correct
> >>>> debug1: SSH2_MSG_NEWKEYS sent
> >>>> debug1: expecting SSH2_MSG_NEWKEYS
> >>>> debug1: SSH2_MSG_NEWKEYS received
> >>>> debug1: SSH2_MSG_SERVICE_REQUEST sent
> >>>> debug1: SSH2_MSG_SERVICE_ACCEPT received
> >>>> debug1: Authentications that can continue:
> >>>> publickey,keyboard-interactive,hostbased
> >>>> debug1: Next authentication method: publickey
> >>>> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
> >>>> debug1: Server accepts key: pkalg ssh-rsa blen 277
> >>>> debug1: read PEM private key done: type RSA
> >>>> debug1: Authentication succeeded (publickey).
> >>>> debug1: channel 0: new [client-session]
> >>>> debug1: Entering interactive session.
> >>>> Last login: Thu Dec 11 20:15:10 2008 from login6-data.surveyor.alcf.anl.gov
> >>>> BusyBox v1.4.2 (2008-05-07 02:58:20 UTC) Built-in shell (ash)
> >>>> Enter 'help' for a list of built-in commands.
> >>>> /gpfs/home/zzhang $
> >>>>>> zhao
> >>>>>>> Have you installed the public key on ion-1?
> >>>>>>> On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
> >>>>>>>> Then it failed
> >>>>>>>> ang -i /home/zzhang/.ssh/id_rsa ion-7
> >>>>>>>> debug1: Connecting to ion-7 [172.16.3.7] port 22.
> >>>>>>>> debug1: Host 'ion-7' is known and matches the RSA host key.
> >>>>>>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
> >>>>>>>> debug1: Next authentication method: keyboard-interactive
> >>>>>>>> debug1: No more authentication methods to try.
> >>>>>>>> Permission denied (publickey,keyboard-interactive,hostbased).
> >>>>>>>>> I looked at the ssh logs, and it seems like you're logging in using
> >>>>>>>>> hostbased authentication.
> >>>>>>>>> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
> >>>>>>>>> Also, note that you misspelled "id_rsa": Warning: Identity
> >>>>>>>>> file /home/zzhang/.ssh/ir_rsa not accessible: No such
> >>>>>>>>> file or directory.
> >>>>>>>>> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
> >>>>>>>>>> Ha, you are right, i put a wrong log here.
> >>>>>>>>>> I rerun it, if failed with the following message.
> >>>>>>>>>> RunID: 20081211-1850-rcrr2fk0
> >>>>>>>>>> Progress:
> >>>>>>>>>> echo started
> >>>>>>>>>> echo failed
> >>>>>>>>>> Execution failed:
> >>>>>>>>>> Caused by:
> >>>>>>>>>> Error while communicating with the SSH server on 172.16.3.7:22
> >>>>>>>>>> Caused by:
> >>>>>>>>>>         Public Key Authentication failed
> >>>>>>>>>> zhao
> >>>>>>>>>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
> >>>>>>>>>>>> sure, it is 172.16.3.6.passphrase=
> >>>>>>>>>>> I don't believe you. Can you paste the file?
> >>>>>>>>>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
> >>>>>>>>>>>>>> Hi, Mihael
> >>>>>>>>>>>>>> If I put .passphrase= there, I got this:
> >>>>>>>>>>>>> With the IP address before .passphrase, of course. I.e.
