[Swift-devel] ssh data provider
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Dec 11 20:57:44 CST 2008
You could ask the folks who administer the BG to enable sftp on the io
nodes. This is enabled by default with openssh.
On Thu, 2008-12-11 at 20:52 -0600, Zhao Zhang wrote:
> got this
> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
> -tc.file ./tc.data first.swift
> Swift svn swift-r2334 (Swift modified locally) cog-r2216
> RunID: 20081211-2021-oi8c3r0b
> Progress:
> echo started
> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
> echo failed
> Execution failed:
>         Could not initialize shared directory on bgp000
> Caused by:
>         org.globus.cog.abstraction.impl.file.FileResourceException:
> Error while communicating with the SSH server on 172.16.3.2:22
> Caused by:
>         Failed to start the SFTP subsystem on zzhang:<key>@172.16.3.2:22
> Mihael Hategan wrote:
> > now try swift
> >>> On Thu, 2008-12-11 at 20:00 -0600, Zhao Zhang wrote:
> >>>> nope, we don't need to since ssh works for us.
> >>> Mmm, obviously not. May I suggest typing "man ssh" and reading the
> >>> section on authentication?
> >> By "it works" I mean it works for our ordinary use, we could login IO
> >> nodes with that host based authentication.
> >>>>  Besides, I have no idea
> >>>> where the ssh on IO nodes saves the public key.
> >>> For public key authentication you need to put the public
> >>> key (~/.ssh/id_rsa.pub) in ~/.ssh/authorized_keys on the remote
> >>> machine. This is the public key that corresponds to your private key.
> >> Ha, it works now.
> >> zzhang at login6.surveyor:~/swift/test> ssh -v -o
> >> HostbasedAuthentication=no -l zzh
> >> ang -i /home/zzhang/.ssh/id_rsa ion-1
> >> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
> >> debug1: Reading configuration data /etc/ssh/ssh_config
> >> debug1: Applying options for *
> >> debug1: /etc/ssh/ssh_config line 25: Deprecated option
> >> "RhostsAuthentication"
> >> debug1: Connecting to ion-1 [172.16.3.1] port 22.
> >> debug1: Connection established.
> >> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
> >> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
> >> debug1: match: OpenSSH_4.2 pat OpenSSH*
> >> debug1: Enabling compatibility mode for protocol 2.0
> >> debug1: Local version string SSH-2.0-OpenSSH_4.2
> >> debug1: SSH2_MSG_KEXINIT sent
> >> debug1: SSH2_MSG_KEXINIT received
> >> debug1: kex: server->client aes128-cbc hmac-md5 none
> >> debug1: kex: client->server aes128-cbc hmac-md5 none
> >> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
> >> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
> >> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
> >> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
> >> debug1: Host 'ion-1' is known and matches the RSA host key.
> >> debug1: Found key in /home/zzhang/.ssh/known_hosts:40
> >> Warning: the RSA host key for 'ion-1' differs from the key for the IP
> >> address '172.16.3.1'
> >> Offending key for IP in /home/zzhang/.ssh/known_hosts:3
> >> Matching host key in /home/zzhang/.ssh/known_hosts:40
> >> debug1: ssh_rsa_verify: signature correct
> >> debug1: SSH2_MSG_NEWKEYS sent
> >> debug1: expecting SSH2_MSG_NEWKEYS
> >> debug1: SSH2_MSG_NEWKEYS received
> >> debug1: SSH2_MSG_SERVICE_REQUEST sent
> >> debug1: SSH2_MSG_SERVICE_ACCEPT received
> >> debug1: Authentications that can continue:
> >> publickey,keyboard-interactive,hostbased
> >> debug1: Next authentication method: publickey
> >> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
> >> debug1: Server accepts key: pkalg ssh-rsa blen 277
> >> debug1: read PEM private key done: type RSA
> >> debug1: Authentication succeeded (publickey).
> >> debug1: channel 0: new [client-session]
> >> debug1: Entering interactive session.
> >> Last login: Thu Dec 11 20:15:10 2008 from login6-data.surveyor.alcf.anl.gov
> >> BusyBox v1.4.2 (2008-05-07 02:58:20 UTC) Built-in shell (ash)
> >> Enter 'help' for a list of built-in commands.
> >> /gpfs/home/zzhang $
> >>>> zhao
> >>>>> Have you installed the public key on ion-1?
> >>>>> On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
> >>>>>> Then it failed
> >>>>>> ang -i /home/zzhang/.ssh/id_rsa ion-7
> >>>>>> debug1: Connecting to ion-7 [172.16.3.7] port 22.
> >>>>>> debug1: Host 'ion-7' is known and matches the RSA host key.
> >>>>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
> >>>>>> debug1: Next authentication method: keyboard-interactive
> >>>>>> debug1: No more authentication methods to try.
> >>>>>> Permission denied (publickey,keyboard-interactive,hostbased).
> >>>>>>> I looked at the ssh logs, and it seems like you're logging in using
> >>>>>>> hostbased authentication.
> >>>>>>> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
> >>>>>>> Also, note that you misspelled "id_rsa": Warning: Identity
> >>>>>>> file /home/zzhang/.ssh/ir_rsa not accessible: No such
> >>>>>>> file or directory.
> >>>>>>> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
> >>>>>>>> Ha, you are right, i put a wrong log here.
> >>>>>>>> I rerun it, if failed with the following message.
> >>>>>>>> RunID: 20081211-1850-rcrr2fk0
> >>>>>>>> Progress:
> >>>>>>>> echo started
> >>>>>>>> echo failed
> >>>>>>>> Execution failed:
> >>>>>>>> Caused by:
> >>>>>>>> Error while communicating with the SSH server on 172.16.3.7:22
> >>>>>>>> Caused by:
> >>>>>>>>         Public Key Authentication failed
> >>>>>>>> zhao
> >>>>>>>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
> >>>>>>>>>> sure, it is 172.16.3.6.passphrase=
> >>>>>>>>> I don't believe you. Can you paste the file?
> >>>>>>>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
> >>>>>>>>>>>> Hi, Mihael
> >>>>>>>>>>>> If I put .passphrase= there, I got this:
> >>>>>>>>>>> With the IP address before .passphrase, of course. I.e.
