[Swift-devel] ssh data provider
Zhao Zhang zhaozhang at uchicago.edu
Thu Dec 11 20:52:28 CST 2008
got this
zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
-tc.file ./tc.data first.swift
Swift svn swift-r2334 (Swift modified locally) cog-r2216
RunID: 20081211-2021-oi8c3r0b
Progress:
echo started
Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
echo failed
Execution failed:
        Could not initialize shared directory on bgp000
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Error while communicating with the SSH server on 172.16.3.2:22
Caused by:
        Failed to start the SFTP subsystem on zzhang:<key>@172.16.3.2:22
Mihael Hategan wrote:
> now try swift
>>> On Thu, 2008-12-11 at 20:00 -0600, Zhao Zhang wrote:
>>>> nope, we don't need to since ssh works for us.
>>> Mmm, obviously not. May I suggest typing "man ssh" and reading the
>>> section on authentication?
>> By "it works" I mean it works for our ordinary use, we could login IO
>> nodes with that host based authentication.
>>>>  Besides, I have no idea
>>>> where the ssh on IO nodes saves the public key.
>>> For public key authentication you need to put the public
>>> key (~/.ssh/id_rsa.pub) in ~/.ssh/authorized_keys on the remote
>>> machine. This is the public key that corresponds to your private key.
>> Ha, it works now.
>> zzhang at login6.surveyor:~/swift/test> ssh -v -o
>> HostbasedAuthentication=no -l zzh
>> ang -i /home/zzhang/.ssh/id_rsa ion-1
>> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
>> debug1: Reading configuration data /etc/ssh/ssh_config
>> debug1: Applying options for *
>> debug1: /etc/ssh/ssh_config line 25: Deprecated option
>> "RhostsAuthentication"
>> debug1: Connecting to ion-1 [172.16.3.1] port 22.
>> debug1: Connection established.
>> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
>> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
>> debug1: match: OpenSSH_4.2 pat OpenSSH*
>> debug1: Enabling compatibility mode for protocol 2.0
>> debug1: Local version string SSH-2.0-OpenSSH_4.2
>> debug1: SSH2_MSG_KEXINIT sent
>> debug1: SSH2_MSG_KEXINIT received
>> debug1: kex: server->client aes128-cbc hmac-md5 none
>> debug1: kex: client->server aes128-cbc hmac-md5 none
>> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
>> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
>> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
>> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
>> debug1: Host 'ion-1' is known and matches the RSA host key.
>> debug1: Found key in /home/zzhang/.ssh/known_hosts:40
>> Warning: the RSA host key for 'ion-1' differs from the key for the IP
>> address '172.16.3.1'
>> Offending key for IP in /home/zzhang/.ssh/known_hosts:3
>> Matching host key in /home/zzhang/.ssh/known_hosts:40
>> debug1: ssh_rsa_verify: signature correct
>> debug1: SSH2_MSG_NEWKEYS sent
>> debug1: expecting SSH2_MSG_NEWKEYS
>> debug1: SSH2_MSG_NEWKEYS received
>> debug1: SSH2_MSG_SERVICE_REQUEST sent
>> debug1: SSH2_MSG_SERVICE_ACCEPT received
>> debug1: Authentications that can continue:
>> publickey,keyboard-interactive,hostbased
>> debug1: Next authentication method: publickey
>> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
>> debug1: Server accepts key: pkalg ssh-rsa blen 277
>> debug1: read PEM private key done: type RSA
>> debug1: Authentication succeeded (publickey).
>> debug1: channel 0: new [client-session]
>> debug1: Entering interactive session.
>> Last login: Thu Dec 11 20:15:10 2008 from login6-data.surveyor.alcf.anl.gov
>> BusyBox v1.4.2 (2008-05-07 02:58:20 UTC) Built-in shell (ash)
>> Enter 'help' for a list of built-in commands.
>> /gpfs/home/zzhang $
>>>> zhao
>>>>> Have you installed the public key on ion-1?
>>>>> On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
>>>>>> Then it failed
>>>>>> ang -i /home/zzhang/.ssh/id_rsa ion-7
>>>>>> debug1: Connecting to ion-7 [172.16.3.7] port 22.
>>>>>> debug1: Host 'ion-7' is known and matches the RSA host key.
>>>>>> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
>>>>>> debug1: Next authentication method: keyboard-interactive
>>>>>> debug1: No more authentication methods to try.
>>>>>> Permission denied (publickey,keyboard-interactive,hostbased).
>>>>>>> I looked at the ssh logs, and it seems like you're logging in using
>>>>>>> hostbased authentication.
>>>>>>> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
>>>>>>> Also, note that you misspelled "id_rsa": Warning: Identity
>>>>>>> file /home/zzhang/.ssh/ir_rsa not accessible: No such
>>>>>>> file or directory.
>>>>>>> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
>>>>>>>> Ha, you are right, i put a wrong log here.
>>>>>>>> I rerun it, if failed with the following message.
>>>>>>>> RunID: 20081211-1850-rcrr2fk0
>>>>>>>> Progress:
>>>>>>>> echo started
>>>>>>>> echo failed
>>>>>>>> Execution failed:
>>>>>>>> Caused by:
>>>>>>>> Error while communicating with the SSH server on 172.16.3.7:22
>>>>>>>> Caused by:
>>>>>>>>         Public Key Authentication failed
>>>>>>>> zhao
>>>>>>>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
>>>>>>>>>> sure, it is 172.16.3.6.passphrase=
>>>>>>>>> I don't believe you. Can you paste the file?
>>>>>>>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
>>>>>>>>>>>> Hi, Mihael
>>>>>>>>>>>> If I put .passphrase= there, I got this:
>>>>>>>>>>> With the IP address before .passphrase, of course. I.e.
