[Swift-devel] several alternatives to design the data management system for Swift on SuperComputers
Ioan Raicu iraicu at cs.uchicago.edu
Mon Dec 1 17:10:03 CST 2008
Mihael Hategan wrote:
> On Mon, 2008-12-01 at 16:52 -0600, Ioan Raicu wrote:
>> I don't think you realize how expensive GPFS access is when doing so
>> at 100K CPU scale.
> I don't think I understand what you mean by "access". As I said, things
> that generate contention are going to be slow.
> If the problem requires that contention to happen, then it doesn't
> matter what the solution is. If it does not, then I suspect that there
> is a way to avoid contention in GPFS, too (sticking things in different
> directories).
The basic idea is that many smaller shared file systems will scale
better than 1 large file system, as the contention is localized. The
problem is that having 1 global namespace is simple and straight
forward, but having N local namespaces is not, and requires extra
management. If we try to beat GPFS by implementing a global
shared/parallel file system, we are likely to fail, as Ben or you
already mentioned... but by changing the landscape a bit by splitting
the single large global space into many smaller spaces, we should gain
scalability and performance larger scales.
Ioan
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20081201/325147d9/attachment.html>
