[Swift-devel] Swift run: hanging up when submitting a job
Ben Clifford benc at hawaga.org.uk
Tue Aug 12 07:06:45 CDT 2008
On Sun, 10 Aug 2008, Mihael Hategan wrote:
> The other solution is to put a cap on the process duration. So if the
> job has a walltime spec, consider notifications lost if the job doesn't
> complete in walltime + some_margin_of_error.
I think that is probably a good thing to do. Either consider the job
failed if the walltime + margin passes or some polling such as poa single
time when walltime+margin has passed.
Margin can be pretty big (on the order of minutes), I think.
