[Swift-devel] coastersPerNode not recognized by GT2 GRAM
    Ben Clifford
    benc at hawaga.org.uk
    Sun Aug  3 06:07:54 CDT 2008
On Sat, 2 Aug 2008, Michael Wilde wrote:
> I still failed with same error. The gram log showed the coasterspernode rsl
> variable still getting through to gram (below).  I added a second string,
> "coasterspernode" to your list of parameters to filter out, in all lower case,
> and this worked.
> When you tested against a TG site, did you verify that the coasterspernode
> attribute wasnt getting in the RSL?
No; I checked that jobs ran OK - liekly I used the same capitalisation as
in the source and you did not.
Its a case sensitivity bug which should be straightforward to fix.
